Fax calls work over h323 but not sip
Hi All,
I have an issue where fax calls fail after the reinvite with the fax parameters.
If i change this to h323 it works fine.
If i look in the log i see:
SDPOfferInd: T38-SIP: Rejecting incoming T.38 invite. The MTP does not support Pass Thru for FAX. mPeerXferMode=10,mPeerCapCount=6  |2,100,213,1.32601^10.128.16.50^*
If i configure an mtp with pass through i see in the log that the T38 is sending more messages but there is still no high pitch screech after the initial tone.
It also breaks other fax calls if i force MTP on the trunk.
Log attached.
dd="7701"
Cheers
Kev
164
