FAX config on 2811??
I have a 2811 VGW registered to CUCM 7.02, is it an H.323 gateway.  Local PSTN is coming in on a PRI circuit connected to the VIC-2TMFT-T1/E1.  One of the inbound numbers on that PRI is a fax number (5551236789) that I need to port out of the FXS card (voice-port 0/2/0) to the fax machine.  Also need to allow for outbound fax sending.
Would someone mind posting sample config that will help me understand and accomplish this?  I find plenty of examples, but don't completely understand what is pertinent for creating both inbound/outbound config.
dial-peer voice 21 pots
description Fax
destination-pattern 5551236789
port 0/0/0:23
forward-digits 0
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
fax rate voice
voice-port 0/2/0
translation-profile incoming Fax
description Fax
Jason
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: FAX config on 2811??
First, your incoming dial peer should cover all incoming calls on the PRI and include the direct-inward-dial command. This will cover you for the inbound call leg. The outbound dial peer could look something like this:
description Fax
destination-pattern 5551236789 <-- This assumes that the provider is sending you 10 digits on the PRI.
incoming called-number . <-- This is used to match this as an incoming dial peer for outbound faxes.
voice-port 0/2/0
codec g711ulaw  <-- used for passthrough
fax rate voice <-- used for passthrough
fax protocol t38  ls-redundancy 0 hs-redundancy 0 fallback cisco <--used for fax relay
You do not need both the passthrough or relay commands. I would recommend just using the relay command.
Please remember to rate helpful responses and identify helpful or
Hall of Fame Super Gold
You don't need any fax commands for that.
Just configure the DP with the right numbers, and that's all.
VIP Super Bronze
description Fax
voice-port 0/2/0
Thank you Jonathan.
317
