Showing results forĀ
Search instead forĀ
Did you mean:Ā
Fax configuration on cisco 2811 Router
sameermunj
I Have cisco 2811 router being used as voip router.we have 4 port FXO card installed in teh router.i need to configure the fxo card for  fax application.i am totally new to this.can someone share the sample configuration for the same.
paolo bevilacqua
Use the search box on main cisco page, for example "configuring fax relay".
Note if you are the end user you would save time and frustration hiring a professional for the job.
