Community Member
fax connected to fxs get's busy tone
We have a remote site with a 2811 running 12.4(13r)T
There are 4 BRI ports and 2 FXS ports.
I have a fax connected to fxs 0/1/0
The dial-peers are configured like this :
dial-peer voice 7575 pots
destination-pattern 7575
port 0/1/0
The voice-port has the default configuration :
voice-port 0/1/0
voice-port 0/1/1
I can see when calling the fax number from a mobile phone that the BRI port becomes active
and the fxs goes to ringing :
CHSOSANyonISR#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxs-ls up up on-hook ringing y
0/1/1 -- fxs-ls up dorm on-hook idle y
0/2/0 1 bri-voice up dorm none none y
0/2/0 2 bri-voice up dorm none none y
0/2/1 1 bri-voice up dorm none none y
0/2/1 2 bri-voice up dorm none none y
0/3/0 1 bri-voice up dorm none none y
0/3/0 2 bri-voice up dorm none none y
0/3/1 1 bri-voice up up none none y
0/3/1 2 bri-voice up dorm none none y
50/0/1 1 efxs up up on-hook idle y
50/0/2 1 efxs up up on-hook idle y
50/0/3 1 efxs up up on-hook idle y
50/0/4 1 efxs up up on-hook idle y
50/0/5 1 efxs up up on-hook idle y
50/0/6 1 efxs up up on-hook idle y
However, I get a busy tone directly after this.
Any help will be much appreciated.
Rgds,
Jeroen
Hall of Fame Super Gold
Re: fax connected to fxs get's busy tone
Hi, you need to take a trace with "debug isdn q931" and "term mon" to debug this.
Community Member
Thanks for your reply. I noticed that when I call the number, I first get a second dal tone for about 10 seconds and then I get the busy tone. This is the output of the debug :
001083: *Jul 3 12:17:51.571 PCTime: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '75'
Plan:ISDN, Type:Unknown
001084: *Jul 3 12:17:51.599 PCTime: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
001085: *Jul 3 12:17:51.615 PCTime: ISDN BR0/2/0 Q931: TX -> PROGRESS pd = 8 callref = 0x81
Progress Ind i = 0x8188 - In-band info or appropriate now available
001086: *Jul 3 12:17:52.511 PCTime: ISDN BR0/2/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8182 - Destination address is non-ISDN
001087: *Jul 3 12:17:52.587 PCTime: ISDN BR0/2/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
001088: *Jul 3 12:17:52.591 PCTime: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to N/A N/A
001089: *Jul 3 12:17:58.591 PCTime: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to N/A N/A
001090: *Jul 3 12:18:07.539 PCTime: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
001091: *Jul 3 12:18:07.543 PCTime: %ISDN-6-DISCONNECT: Interface BRI0/2/0:1 disconnected from unknown , call lasted 14 seconds
001092: *Jul 3 12:18:07.563 PCTime: ISDN BR0/2/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
001093: *Jul 3 12:18:07.623 PCTime: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
I presume the port does not know what to do with the call.
Thanks for your help,
Jeroen
Hi, destination-pattern should be 75 as this is the number you're receiving.
Also check that you have configured;
network-clock-participate wic 2
network-clock-select 1 bri 0/2/0
network-clock-select 2 bri 0/2/1
If still problems collect "debug vpm signal" together with "isdn q931".
Community Member
But I'm translating this number to make it a 4 digit number 7575 as you can see in the output of the show call active voice (when I'm placing a call to the number) :
Strange thing is I have 3 call-legs (see attached output)?
Jeroen
Hi, the translation cannot be checked from the debug you sent. Anyway, you still need to network-clock commands.
It is known that sometime calls remain hanging (never fixed bugs). The only solution is to reload router as they are non-cleanable.
Community Member
Please find attached the trace with the Voice Port Module signaling debugging is on
Also, I have 2 wic's with each 2 bri's, do I need to network clock command for both?
Jeroen
For this trace the disconnection came from remote party. Was it taken with the network-clock commands in place? And yes you need them exactly as I've referenced above.
Community Member
Hi....
Im wondering if you have solved this issue, as im having a very similar case !!
please advice !!
regards,
390
