Fax G711 to T.38 Problem
Hi everybody,
I have a problem with my Voice Gtaeway 1760 concerning fax issue!!
I think that the problem is that the Gateway is unable to change the codec from G711ulaw to T.38 !! and i don't know why!
My test is simple: i call the number via PSTN and i expect that tone change to modem but i don't hear that, and when i use the command "sh voice call status" i can see the call but the codec is G711 and i doesn't change to t.38!!
could the problem be because of DSP?
PlZ help me it's really urgent.
Thank in advance
1 REPLY
Re: Fax G711 to T.38 Problem
Sorry, here it the dial peers i'm using :
-------Dial-peer for incoming PSTN Call---------
dial-peer voice 100 pots
incoming called-number ..
direct-inward-dial
-------Dial-Peer voip pointing to the fax server------
dial-peer voice 10 voip
description -- To FAX Server
destination-pattern 6.
session target ipv4:172.16.110.110
dtmf-relay h245-alphanumeric
codec g711ulaw
i used also these command ::
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
Thx again
357
