FAX Machine Compatibility on VG224
Hi experts,
Do we have any FAX Machine Compatibility matrix or something similar on VG224 ? Because my customer can not get the HP fax machine work on VG224.
Henry
Everyone's tags (1)
1 REPLY
Re: FAX Machine Compatibility on VG224
Dear Henry;
This forum does not provide support for VG224, I suggest you try NetPro.
What I can tell you is that HP faxes typically has issues with ATAs, not sure if it is because of signal levels or impedance.
Regards;
Alberto
1262
