Fax Machine Issue on VG224
Am having an issue with a fax machine that is attached to our VG224. When you log into Call Manager it is not showing as registered on the VG224, i have reset and restarted it via Call Manager but no joy, I have also try using another port but it is not working either. Any ideas?
Hall of Fame Super Gold
Re: Fax Machine Issue on VG224
At very least, you need to mention which protocol you are using between CM, VG224, and PSTN GW
Sorry about the rating ...I was showing someone the new rating system.
And he clicked on one star.
This was accidental is there a way to revert this ?
It is not a good system, single-click operation leads to frequent mistakes.
You can only rate other posts to compensate.
207
