04-09-2009 01:42 AM - edited 03-15-2019 05:23 PM
I m trying to set up FAX-MAIL on 2801 with this IOS :
c2801-ipvoicek9-mz.124-4.XC.bin
I want to receive fax on this external number : 0467XXXXXX and to forward them to fax@fax-mail.com on a server A.B.C.D.
Here the part concerned by this configuration :
dial-peer voice 7932 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern XXXXXXXX
information-type fax
session target mailto:fax-in@oc3n.net
dial-peer voice 7933 pots
service onramp
incoming called-number XXXXXXXX
direct-inward-dial
For the called number and destination pattern I have put the full number externa without the 0.
Like 0123456789 => 123456789
Here the symptom, I try to call, and the operator tells me : Unknow number.
I Have 20 number attributed from the operator and this 1 is between 2 of them.
Do I have miss a thing ?
Solved! Go to Solution.
04-09-2009 01:46 AM
Check with "debug isdn q931" and "term mon" that your XXXXX number is exactly as received from telco. Also, check with "debug voice application script" that no other errors are thrown.
04-09-2009 01:46 AM
04-09-2009 01:54 AM
Thanks for your answer.
I Have that
Apr 9 09:51:46.925: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0/2/1, TEI 0 changed to up
Apr 9 09:51:46.933: %LINK-3-UPDOWN: Interface BRI0/2/1, changed state to up
Apr 9 09:51:47.001: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8 callref = 0x39
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x2183, 'XXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, 'AAAAAAAA'
Apr 9 09:51:47.017: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8 callref = 0xB9
Channel ID i = 0x8A
Exclusive, B2
Apr 9 09:51:47.049: ISDN BR0/2/1 Q931: TX -> DISCONNECT pd = 8 callref = 0xB9
Cause i = 0x8081 - Unallocated/unassigned number
Apr 9 09:51:47.101: ISDN BR0/2/1 Q931: RX <- RELEASE pd = 8 callref = 0x39
Apr 9 09:51:47.105: ISDN BR0/2/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB9
Where AAAAA is the good number for the fax
04-09-2009 02:05 AM
Means the configuration is not complete:
application
service xxx
Note you need a reboot to make the embedded script appear after configuration.
04-09-2009 02:21 AM
Oh I have forget to paste that :
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server A.B.C.D port 25
mta send with-subject both
mta send mail-from hostname gw.fax.net
mta send mail-from username $s$
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
Already done.
But, When I configure an ephone I just indicate the last 4 digit. like 7932. Not the complete number.
Do you think It could be that ?
04-09-2009 02:24 AM
No, it is not that. Have you rebooted the router? The dubug command I've indicated above will tell you if any problem with the script.
04-09-2009 02:29 AM
Yes, and to be sure, I reload it again now.
Same problem after the reload
04-09-2009 02:55 AM
Ok, I haven't seen that i have a translation rule. I change the full number for just the last 4 digit.
It's anwsering now, but the .tif received is only 2 octet.
Perhaps there is another problem.
04-09-2009 03:01 AM
Try XC7, or even better, a newer IOS.
04-20-2009 11:07 PM
I have updated to
c2801-ipvoicek9-mz.124-4.XC7.bin
And still have the same problem.
In fact I have incomplete Fax with :
- A normal fax connect to ATA188
- H323 FAX with T38modem and Hylafax
- fax-mail from cisco.
In attachement, an exemple of the incomplete fax. One received by Hylafax with T38modem, and other with T37 onramp fax-mail.
05-25-2009 01:19 AM
I ve tried with another IOS, another router, with another line (E1/ T2 in france) and have still this problem.
When I send only 1 page document : No problem all is fine.
When I send 2/3 page : The fax is not complete....
It seems like the router cannot handle big fax in T37 mode...
Some one could help me on this problem ?
05-25-2009 03:00 AM
I have a better idea... which IOS do I have to buy for make this T37 working ?
