FAX not working with ATA 186
One of our customer is having Callmanager version 6.1. They have a remote branch with SRST configured gateway and a PRI connection.
They are facing problem of sending and recieving FAX. When they are trying to send fax its reach to the gateway and there is an error message showing on the fax machine " Comm. Error". We have tested with defferent fax machine and ATA adaptor but problem is not getting resolved.  Also we have upgraded the firmware of the ATA adaptor.
Can anybody help me to resolve this issue
Thejas
Re: FAX not working with ATA 186
Hello Thejas,
I can offer a suggestion that may help, but ultimately, ATA-186 isn't supported for fax.  People use it, but if you have trouble with it, you're on your own.  One of the VG units (VG202, VG204, etc.) is a supported, although more expensive, way to solve the issue.
Often with the ATA-186, the issue is really something you can solve with the fax machine itself.  The fax machine doesn't know it's on an VOIP line.  This is a problem because it really doesn't reliably support transmission rates above 14.4.  If you want it rock solid, you need to crank it down to 9600 bps.  The fax machines will attempt to negotiate the highest speed they can get.  If this is above what the voip line supports, you will experience data loss, and the call will be dropped with a communications error.
Some fax machines do not have the option to turn the max transmission speed down.  Some do.  If your machine doesn't, you'll either need to get a fax machine that does support a manually set speed, get a separate analog line outside the voip solution, or engineer it differently (i.e. in a way that doesn't involve the ATA-186).
Dear McGlamry,
Thank you for your respond.
Actually they have the same type of ATA adaptor and FAX machine at there head office and it is working fine there.
So that mean ATA186 over the WAN is not supported ?
Thejas
Didn't say it won't work. Only that it's not supported...i.e. Cisco isn't going to help you with problems with it.
NOTICE OF CONFIDENTIALITY:
The information contained in this email transmission is confidential information which may contain information that is legally privileged and prohibited from disclosure under applicable law or by contractual agreement. The information is intended solely for the use of the individual or entity named above.
If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or taking of any action in reliance on the contents of this email transmission is strictly prohibited.
If you have received this email transmission in error, please notify us immediately by telephone to arrange for the return of the original transmission to us.
292
