Fax on a CCM5 using a FXS on the gateway controlled with MGCP
Is it possible to use a FAX on a FXS of a Voice Gateway that is controlled with a MGCP on a Call Manager ?
When the fax make call, i want that the CCM route the call to the destination (maybe voip or pstn)
How to do it?
Should add just these configurations ont router, like this :
mgcp modem passthrough voip mode nse
mgcp fax t38 inhibit
dial-peer voice 999100 pots
service mgcpapp
port <FXS_PORT>
The schéma is :
FXS<VoiceGateway>-MCGP-<CCM>
Is There any link to see how to do it?
Best regards,
1 REPLY
Silver
Re: Fax on a CCM5 using a FXS on the gateway controlled with MGC
116
