Fax on SIP-TRUNK
I am facing issues with FAX connecting to ATA 186 they are not able to send fax nor they are able to receive, but if i am connecting anolog phone the call is perfect for in and out ,
Can anybody help me to know what are the standards commnds to put when the VG is in a SIP Trunk.
Hall of Fame Super Silver
SIP-TRUNK
ATA186 do not support protocol based T38 which is what most likely your provider is using. Your options are:
1. Get device that supports T.38, i.e. ATA187
2. Check wit provider to see if they can use fax passthrough and reconfigure your GW to use it.
HTH,
Chris
Re: SIP-TRUNK
Thanks Chris,
Can u tell me the commands to applied on my VG  once i make agree my provider to configure fax passthrough on his end.
Re: SIP-TRUNK
"modem passthrough nse codec g711ulaw"
Either under dial-peer or voice service voip global settings.
HTH, please rate all useful posts!
Chris
Re: SIP-TRUNK
Thanks Chris,
Can you guide me for debugs commands to be confirmed that fax traffic is passng through my VG on SIP TRUNK to my provider.
Re: SIP-TRUNK
debug ccsip messages
show call active voice brief
Chris
227
