Community Member
FAX on the Standard ATA 186
Dear Experts,
I have PRI line I use it to provide phone and fax lines.
The Fax lines are NOT working well specially with long distance numbers.
Should I configure the CallManager some how to fix this OR should I configure the Standard ATA 186 itself?
Community Member
Re: FAX on the Standard ATA 186
On the fax machine, reduce the speed to 9600 baud.
http://www.cisco.com/en/US/ts/fn/100/fn17440.html
Community Member
Dear Mhendren,
Thanks alot for your fast response.
I tries this before but I still have problems.
Shouldn't I tune the ATA itself?
Community Member
I haven't had to tune an ATA before so I really don't know on that.
When you say it's not working well, what is meant by that? Are calls dropping? Not dialing?
Hall of Fame Super Gold
As mentioned in the duplicates of this thread,
Post here output of "show controllers E1" or T1.
Add network-clock-select 1 e1 0/0/0 (fit to your needs) if you have slips on your T1/E1 in show controller t1/e1
Otherwise, make sure you have this configured for H323:
voice service voip
modem passthrough nse code g711ulaw
and this for MGCP:
mgcp modem pass voip mode nse
mgcp fax t38 inhibit
You also want to set these parameters on the ATA:
audio 0x00150015
connect 0x0900400
hth,
nick
397
