Community Member
Fax outgoing issue
I am having an issue regarding a fax machine not unable to make outgoing fax. The fax machine is directly connected to vgw through FXS port.
Incoming fax is working fine but when they are dialling the outgoing number may it be local/long distance the fax machine is giving out busy tone while dialling out.
There is both local and long distance dial peer configured which will route to PRI line.
is there any additional settings required in vgw itself or I need to talk with the service provider.
att-madison1-vgw#
109152: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=13205987631, Called Number=, Voice-Interface=0x41ABA830,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
109153: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=200
109154: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
109155: Nov  5 20:20:02: //-1/F569D8839DBC/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=13205987631
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
  final_redirectNumber =
   hunt_group_timeout =0
109156: Nov  5 20:20:02: //-1/F569D8839DBC/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x41ABA830, Call Info(
   Calling Number=13205987631,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=200, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
109157: Nov  5 20:20:02: //-1/F569D8839DBC/CCAPI/cc_api_call_setup_ind_common:
   Interface Type=3, Protocol=0
109158: Nov  5 20:20:02: //-1/F569D8839DBC/CCAPI/ccCheckClipClir:
   In: Calling Number=13205987631(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
109159: Nov  5 20:20:02: //-1/F569D8839DBC/CCAPI/ccCheckClipClir:
   Calling Party Number Is User Provided
109160: Nov  5 20:20:02: //-1/F569D8839DBC/CCAPI/ccCheckClipClir:
   Out: Calling Number=13205987631(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
109161: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109162: Nov  5 20:20:02: :cc_get_feature_vsa malloc success
109163: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109164: Nov  5 20:20:02:  cc_get_feature_vsa count is 1
109165: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109166: Nov  5 20:20:02: :FEATURE_VSA attributes are: feature_name:0,feature_time:1035812520,feature_id:3767
109167: Nov  5 20:20:02: //3767/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
109168: Nov  5 20:20:02: //3767/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1
109169: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_init_call_entry:
   call_init_entry calle is 42AB5388,callid is 3767
109170: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_init_call_entry:
109171: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=3767
109172: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=13205987631(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
109173: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_api_insert_call_active_entry:
109174: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_incr_if_call_volume:
109175: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_process_call_setup_ind:
   Event=0x41A64150
109176: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=, Call Transfer Consult Id=
109177: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
109178: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
109179: Nov  5 20:20:02: Comparing SSOpCode; 0x50 and 0x0
109180: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
109181: Nov  5 20:20:02: Comparing SSOpCode; 0x12 and 0x0
109182: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   No Matching Node
109183: Nov  5 20:20:02: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitializePID:
   Application Process Name=_ManagedAppProcess_Default, Application Process Id=432, Application Handle=0x42A8F9E4
109184: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/ccCallSetContext:
   Context=0x3A4987F0
109185: Nov  5 20:20:02: //3767/F569D8839DBC/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 3767 with tag 200 to app "_ManagedAppProcess_Default"
109186: Nov  5 20:20:03: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitialize:
   Application Name=_ManagedAppProcess_Default, Application Process Id=432, Application Handle=0x42B3AA08
109187: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/ccCallSetupAck:
   Call Id=3767
109188: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
109189: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/cc_api_set_transfer_info:
   Call Transfer Reset
109190: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=3767
109191: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
109192: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
109193: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/ccCallReportDigits:
   (callID=0xEB7, digit_event=0x1, enable=TRUE, consume=FALSE)
109194: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=3767
109195: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x41ABA830, callID=0xEB7, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
109196: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x41ABA830, Call Id=3767
109197: Nov  5 20:20:03: //3767/F569D8839DBC/CCAPI/cc_api_call_report_digits_done:
att-madison1-vgw#Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
109198: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109199: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=3767, Digit=8, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D1A42, Rtp Expiration=0x0
109200: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109201: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=8, Duration=112,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
109202: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
109203: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8, Peer Info Type=DIALPEER_INFO_SPEECH
109204: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8
109205: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
109206: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=8, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109207: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
att-madison1-vgw#Result=MORE_DIGITS_NEEDED(1)
109208: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109209: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3767, Digit=1, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D234A, Rtp Expiration=0x0
109210: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109211: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=1, Duration=110,
109212: Nov  5 20:20:04: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109213: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=81, Peer Info Type=DIALPEER_INFO_SPEECH
109214: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=81
109215: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109216: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=81, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109217: Nov  5 20:20:04: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109218: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109219: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3767, Digit=5, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D2C0A, Rtp Expiration=0x0
109220: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109221: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=5, Duration=110,
109222: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109223: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=815, Peer Info Type=DIALPEER_INFO_SPEECH
109224: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=815
109225: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109226: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=815, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109227: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109228: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109229: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3767, Digit=0, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D34CA, Rtp Expiration=0x0
109230: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109231: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=0, Duration=120,
109232: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109233: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8150, Peer Info Type=DIALPEER_INFO_SPEECH
109234: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8150
109235: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109236: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=8150, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109237: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109238: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109239: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
att-madison1-vgw#Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=3767, Digit=7, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D3D8A, Rtp Expiration=0x0
109240: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109241: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=7, Duration=120,
109242: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109243: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=81507, Peer Info Type=DIALPEER_INFO_SPEECH
109244: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=81507
109245: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109246: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=81507, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109247: Nov  5 20:20:05: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109248: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109249: Nov  5 20:20:05: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3767, Digit=2, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D464D, Rtp Expiration=0x0
109250: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109251: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=2, Duration=117,
109252: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109253: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=815072, Peer Info Type=DIALPEER_INFO_SPEECH
109254: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=815072
109255: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109256: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=815072, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109257: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109258: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109259: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3767, Digit=4, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D4F0D, Rtp Expiration=0x0
109260: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109261: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=4, Duration=117,
109262: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109263: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8150724, Peer Info Type=DIALPEER_INFO_SPEECH
109264: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8150724
109265: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109266: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=8150724, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109267: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109268: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109269: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x589D57CD, Rtp Expiration=0x0
109270: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109271: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=7, Duration=117,
109272: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109273: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=81507247, Peer Info Type=DIALPEER_INFO_SPEECH
109274: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=81507247
att-madison1-vgw#
109275: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109276: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=81507247, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109277: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109278: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109279: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x589D608F, Rtp Expiration=0x0
109280: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109281: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=5, Duration=115,
109282: Nov  5 20:20:06: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109283: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=815072475, Peer Info Type=DIALPEER_INFO_SPEECH
109284: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=815072475
109285: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109286: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=815072475, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109287: Nov  5 20:20:06: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109288: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109289: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3767, Digit=3, DigitBeginFlags=0x1,
   Rtp Timestamp=0x589D694F, Rtp Expiration=0x0
109290: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109291: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=3, Duration=115,
109292: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109293: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8150724753, Peer Info Type=DIALPEER_INFO_SPEECH
109294: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8150724753
109295: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109296: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=8150724753, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109297: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109298: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109299: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x589D720F, Rtp Expiration=0x0
109300: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109301: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109302: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109303: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=81507247533, Peer Info Type=DIALPEER_INFO_SPEECH
109304: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=81507247533
109305: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109306: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=81507247533, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109307: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
109308: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
109309: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x589D7AD2, Rtp Expiration=0x0
109310: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109311: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
   Source Call Id=3767, Digit=3, Duration=112,
109312: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_digit_end:
109313: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=815072475333, Peer Info Type=DIALPEER_INFO_SPEECH
109314: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=815072475333
109315: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
109316: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=815072475333, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
109317: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=4001
109318: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallActiveUpdateNumbers:
109319: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallReportDigits:
   (callID=0xEB7, digit_event=0x0, enable=FALSE, consume=FALSE)
109320: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallReportDigits:
109321: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x41ABA830, callID=0xEB7, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
109322: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_report_digits_done:
109323: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_report_digits_done:
109324: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
109325: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109326: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109327: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109328: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=815072475333, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
109329: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109330: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109331: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109332: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109333: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
109334: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109335: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=815072475333, Called Number=815072475333, Peer Info Type=DIALPEER_INFO_SPEECH
109336: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109337: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109338: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109339: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109340: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
109341: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
109342: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
109343: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=815072475333, Called Number=, Voice-Interface=0x0,
109344: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
109345: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109346: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
109347: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   Unsupported MLPP Service Domain Network 0
109348: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
   Invalid MLPP Information
109349: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
   Precedence not above Routine
109350: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   BEFORE COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
109351: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   DEST  MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
109352: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
     AFTER COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]   DEST MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
109353: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109354: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109355: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109356: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109357: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109358: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109359: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109360: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109361: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109362: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109363: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
109364: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
109365: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
109366: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109367: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
109368: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
109369: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109370: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109371: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersCore:
109372: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchSafModulePlugin:
   dialstring=815072475333, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
109373: Nov  5 20:20:07: //-1/F569D8839DBC/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109374: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=4001, Params=0x3A48BBE0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
109375: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCheckClipClir:
109376: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCheckClipClir:
109377: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCheckClipClir:
109378: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallSetupRequest:
   Destination Pattern=81[2-9]..[2-9]......, Called Number=815072475333, Digit Strip=TRUE
109379: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallSetupRequest:
   Called Number=815072475333(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=MainFax
   Account Number=, Final Destination Flag=FALSE,
   Guid=F569D883-645F-11E4-9DBC-FED84B3C2726, Outgoing Dial-peer=4001
109380: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=815072475333
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
109381: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x22F9DCD0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=13205987631,(Calling Name=MainFax)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=815072475333(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=4001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
109382: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109383: Nov  5 20:20:07: :cc_get_feature_vsa malloc success
109384: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109385: Nov  5 20:20:07:  cc_get_feature_vsa count is 2
109386: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109387: Nov  5 20:20:07: :FEATURE_VSA attributes are: feature_name:0,feature_time:1035812968,feature_id:3768
109388: Nov  5 20:20:07: //3768/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
109389: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_init_call_entry:
   call_init_entry calle is 42AB6028,callid is 3768
109390: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_init_call_entry:
109391: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=3767, Bindee Call Id=3768
109392: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=3768
109393: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_set_voice_port_value:
109394: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_set_voice_port_value:
   CC_IF_TELEPHONY: Echo=0, Playout=0
109395: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccDirectEventToSPI:
109396: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
109397: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallSetupRequest:exit@2856
109398: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallSetContext:
   Context=0x3A48BB90
109399: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccSaveDialpeerTag:
109400: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_find_feature_vsa:
109401: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallGetContext:
   Context=0x42B3A090, Call Id=3767
109402: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_set_outpulsed_digits:
   outpulsed_dialstring=15072475333 set
109403: Nov  5 20:20:07: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 13205987631
109404: Nov  5 20:20:07: ISDN Se0/1/0:23 Q931: Sending SETUP  callref = 0x02A1 callID = 0x8224 switch = primary-ni interface = User
109405: Nov  5 20:20:07: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x02A1
                Bearer Capability i = 0x9090A2
                                Standard = CCITT
                                Transfer Capability = 3.1kHz Audio
                                Transfer Mode = Circuit
                                Transfer Rate = 64 kbit/s
                Channel ID i = 0xA98397
                                Exclusive, Channel 23
                Progress Ind i = 0x8183 - Origination address is non-ISDN
                Calling Party Number i = 0x0080, '13205987631'
                                Plan:Unknown, Type:Unknown
                Called Party Number i = 0x80, '15072475333'
109406: Nov  5 20:20:07: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x82A1
                Cause i = 0x82E46C - Invalid information element contents
109407: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_insert_call_active_entry:
109408: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_incr_if_call_volume:
109409: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_call_disconnected:
   Cause Value=100, Interface=0x22F9DCD0, Call Id=3768
109410: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=100, Retry Count=0)
109411: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
109412: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=3768
109413: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallDisconnect:
   Cause Value=100, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=100)
109414: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
109415: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallDisconnect:
   Cause Value=100, Call Entry(Disconnect Cause=100)
109416: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallDisconnect:
109417: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallDisconnect:
   Cause Value=100, Call Entry(Responsed=TRUE, Cause Value=100)
109418: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_get_transfer_info:
109419: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
109420: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_insert_call_history:
109421: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccGetCallActiveByCallID:
109422: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccGetCallActiveByCallID:exit@12848
109423: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22F9DCD0, Tag=0x0, Call Id=3768,
   Call Entry(Disconnect Cause=100, Voice Class Cause Code=0, Retry Count=0)
109424: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_disconnect_notify:
109425: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/callStackPop:exit@5101
109426: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
109427: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
109428: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_delete_guid_pod_entry:exit@1206
109429: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109430: Nov  5 20:20:07: :cc_free_feature_vsa freeing 3DBD4060
109431: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109432: Nov  5 20:20:07:  vsacount in free is 1
109433: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_delete_call_entry:
109434: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x3B7A0494]
109435: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=3768
109436: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallGetVoipFlag:
   Flag=FALSE
109437: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=3768
109438: Nov  5 20:20:07: //3768/F569D8839DBC/CCAPI/ccCallSetVoipFlag:
   Call Entry(Voip AAA Flags=0x0)
109439: Nov  5 20:20:07: //3768/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
109440: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/ccGetCallGCID:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
109441: Nov  5 20:20:07: //3768/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109442: Nov  5 20:20:07: //-1/xxxxxxxxxxxx/CCAPI/ccSetCallGCID:
109443: Nov  5 20:20:07: //3768/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109444: Nov  5 20:20:07: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109445: Nov  5 20:20:07: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
109446: Nov  5 20:20:07: //3768/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109447: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallDisconnect:
   Cause Value=100, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
109448: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallDisconnect:
   Call Entry(Incoming=TRUE)
109449: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallDisconnect:
   Cause Value=100, Call Entry(Disconnect Cause=0)
109450: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/ccCallDisconnect:
109451: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_get_transfer_info:
109452: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_get_transfer_info:
109453: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
109454: Nov  5 20:20:07: //3767/F569D8839DBC/CCAPI/cc_api_call_disc_cause_update:
att-madison1-vgw#Call Entry(Disconnect Cause=16)
att-madison1-vgw#
109455: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_api_insert_call_history:
109456: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/ccGetCallActiveByCallID:
109457: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/ccGetCallActiveByCallID:exit@12848
109458: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x41ABA830, Tag=0x0, Call Id=3767,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
109459: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_disconnect_notify:
109460: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/callStackPop:exit@5101
109461: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_api_call_disconnect_done:
109462: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
109463: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_delete_guid_pod_entry:exit@1206
109464: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_delete_call_entry:
   Raw Message=0x41A69B54
109465: Nov  5 20:20:13: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109466: Nov  5 20:20:13: :cc_free_feature_vsa freeing 3DBD3EA0
109467: Nov  5 20:20:13: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109468: Nov  5 20:20:13:  vsacount in free is 0
109469: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
109470: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_delete_call_entry:
   Total Call Count=0
109471: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x3B7A2ADC]
109472: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=3767
109473: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/ccCallGetVoipFlag:
   Flag=FALSE
109474: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=3767
109475: Nov  5 20:20:13: //3767/F569D8839DBC/CCAPI/ccCallSetVoipFlag:
109476: Nov  5 20:20:13: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109477: Nov  5 20:20:13: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
att-madison1-vgw#
109478: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
109479: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
109480: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109481: Nov  5 20:20:31: //-1/06402BBF9DC1/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
109482: Nov  5 20:20:31: //-1/06402BBF9DC1/CCAPI/cc_api_call_setup_ind_common:
109483: Nov  5 20:20:31: //-1/06402BBF9DC1/CCAPI/cc_api_call_setup_ind_common:
109484: Nov  5 20:20:31: //-1/06402BBF9DC1/CCAPI/ccCheckClipClir:
109485: Nov  5 20:20:31: //-1/06402BBF9DC1/CCAPI/ccCheckClipClir:
109486: Nov  5 20:20:31: //-1/06402BBF9DC1/CCAPI/ccCheckClipClir:
109487: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109488: Nov  5 20:20:31: :cc_get_feature_vsa malloc success
109489: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109490: Nov  5 20:20:31:  cc_get_feature_vsa count is 1
109491: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109492: Nov  5 20:20:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1035812520,feature_id:3769
109493: Nov  5 20:20:31: //3769/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
109494: Nov  5 20:20:31: //3769/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1
109495: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_init_call_entry:
   call_init_entry calle is 42AB8608,callid is 3769
109496: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_init_call_entry:
109497: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=3769
109498: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
109499: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_insert_call_active_entry:
109500: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_incr_if_call_volume:
109501: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_process_call_setup_ind:
   Event=0x41A64150
109502: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
109503: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
109504: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
109505: Nov  5 20:20:31: Comparing SSOpCode; 0x50 and 0x0
109506: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
109507: Nov  5 20:20:31: Comparing SSOpCode; 0x12 and 0x0
109508: Nov  5 20:20:31: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   No Matching Node
109509: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccCallSetContext:
   Context=0x3A4892B0
109510: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 3769 with tag 200 to app "_ManagedAppProcess_Default"
109511: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccCallSetupAck:
   Call Id=3769
109512: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_set_transfer_info:
109513: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_set_transfer_info:
   Call Transfer Reset
109514: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=3769
109515: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccSetDigitTimeouts:
109516: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccSetDigitTimeouts:
109517: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccCallReportDigits:
   (callID=0xEB9, digit_event=0x1, enable=TRUE, consume=FALSE)
109518: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=3769
att-madison1-vgw#
109519: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x41ABA830, callID=0xEB9, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
109520: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x41ABA830, Call Id=3769
109521: Nov  5 20:20:31: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
109522: Nov  5 20:20:32: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109523: Nov  5 20:20:32: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=8, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C087C6, Rtp Expiration=0x0
109524: Nov  5 20:20:32: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109525: Nov  5 20:20:32: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=8, Duration=115,
109526: Nov  5 20:20:32: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109527: Nov  5 20:20:32: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109528: Nov  5 20:20:32: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109529: Nov  5 20:20:32: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109530: Nov  5 20:20:32: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
109531: Nov  5 20:20:32: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109532: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109533: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=5, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C09089, Rtp Expiration=0x0
109534: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109535: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=5, Duration=112,
109536: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109537: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=85, Peer Info Type=DIALPEER_INFO_SPEECH
109538: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=85
109539: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109540: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=85, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109541: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109542: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109543: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=0, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C09949, Rtp Expiration=0x0
109544: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109545: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=0, Duration=112,
109546: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109547: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=850, Peer Info Type=DIALPEER_INFO_SPEECH
109548: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=850
109549: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109550: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=850, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109551: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109552: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109553: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=7, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C0A209, Rtp Expiration=0x0
109554: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109555: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=7, Duration=112,
109556: Nov  5 20:20:33: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109557: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8507, Peer Info Type=DIALPEER_INFO_SPEECH
109558: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
att-madison1-vgw#Match Rule=DP_MATCH_DEST; Called Number=8507
109559: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109560: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=8507, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109561: Nov  5 20:20:33: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109562: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109563: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=2, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C0AAC9, Rtp Expiration=0x0
109564: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109565: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=2, Duration=112,
109566: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109567: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=85072, Peer Info Type=DIALPEER_INFO_SPEECH
109568: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=85072
109569: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109570: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=85072, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109571: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109572: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109573: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=4, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C0B3D1, Rtp Expiration=0x0
109574: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109575: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=4, Duration=110,
109576: Nov  5 20:20:34: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
att-madison1-vgw#Call Entry(Handoff Depth=0)
109577: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=850724, Peer Info Type=DIALPEER_INFO_SPEECH
109578: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=850724
109579: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109580: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=850724, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109581: Nov  5 20:20:34: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109582: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109583: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x3C0BC91, Rtp Expiration=0x0
109584: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109585: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=7, Duration=120,
109586: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109587: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109588: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x3C0C551, Rtp Expiration=0x0
109589: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109590: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=5, Duration=120,
109591: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109592: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
109593: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3769, Digit=3, DigitBeginFlags=0x1,
   Rtp Timestamp=0x3C0CE14, Rtp Expiration=0x0
109594: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109595: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
   Source Call Id=3769, Digit=3, Duration=117,
109596: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109597: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8507247, Peer Info Type=DIALPEER_INFO_SPEECH
109598: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8507247
109599: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109600: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=8507247, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
109601: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
109602: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=85072475, Peer Info Type=DIALPEER_INFO_SPEECH
109603: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=85072475
109604: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109605: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=85072475, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
109606: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3001
109607: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallActiveUpdateNumbers:
109608: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallReportDigits:
   (callID=0xEB9, digit_event=0x0, enable=FALSE, consume=FALSE)
109609: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallReportDigits:
109610: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x41ABA830, callID=0xEB9, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
109611: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
109612: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
109613: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=850724753, Peer Info Type=DIALPEER_INFO_SPEECH
109614: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=850724753
109615: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109616: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=850724753, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
109617: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109618: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallActiveUpdateNumbers:
109619: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallReportDigits:
109620: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallReportDigits:
109621: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
109622: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
109623: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_report_digits_done:
109624: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallProceeding:
109625: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109626: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109627: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109628: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=850724753, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
109629: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109630: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109631: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109632: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109633: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
109634: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109635: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=850724753, Called Number=850724753, Peer Info Type=DIALPEER_INFO_SPEECH
109636: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109637: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109638: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109639: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109640: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
109641: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
109642: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109643: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=850724753, Called Number=, Voice-Interface=0x0,
109644: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
109645: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109646: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109647: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109648: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
109649: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
109650: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109651: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109652: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109653: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109654: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109655: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
109656: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109657: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109658: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
109659: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
109660: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109661: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109662: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109663: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
109664: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
109665: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109666: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
109667: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
109668: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
109669: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109670: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109671: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersCore:
109672: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchSafModulePlugin:
   dialstring=850724753, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
109673: Nov  5 20:20:35: //-1/06402BBF9DC1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
109674: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3001, Params=0x3A482CD0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
109675: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCheckClipClir:
109676: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCheckClipClir:
109677: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCheckClipClir:
109678: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallSetupRequest:
   Destination Pattern=8[2-9]......, Called Number=850724753, Digit Strip=TRUE
109679: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallSetupRequest:
   Called Number=850724753(TON=Unknown, NPI=Unknown),
   Guid=06402BBF-6460-11E4-9DC1-FED84B3C2726, Outgoing Dial-peer=3001
109680: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=850724753
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
109681: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=850724753(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3001, Call Count On=FALSE,
109682: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109683: Nov  5 20:20:35: :cc_get_feature_vsa malloc success
109684: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109685: Nov  5 20:20:35:  cc_get_feature_vsa count is 2
109686: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109687: Nov  5 20:20:35: :FEATURE_VSA attributes are: feature_name:0,feature_time:1035812968,feature_id:3770
109688: Nov  5 20:20:35: //3770/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
109689: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_init_call_entry:
   call_init_entry calle is 42AB46E8,callid is 3770
109690: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_init_call_entry:
109691: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=3769, Bindee Call Id=3770
109692: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=3770
109693: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_set_voice_port_value:
109694: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_set_voice_port_value:
109695: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccDirectEventToSPI:
109696: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccIFCallSetupRequestPrivate:
109697: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallSetupRequest:exit@2856
109698: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallSetContext:
   Context=0x3A482C80
109699: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccSaveDialpeerTag:
109700: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_find_feature_vsa:
109701: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallGetContext:
   Context=0x42B3A090, Call Id=3769
109702: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_set_outpulsed_digits:
   outpulsed_dialstring=0724753 set
109703: Nov  5 20:20:35: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 13205987631
109704: Nov  5 20:20:35: ISDN Se0/1/0:23 Q931: Sending SETUP  callref = 0x02A2 callID = 0x8225 switch = primary-ni interface = User
109705: Nov  5 20:20:35: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x02A2
                                Standard = CCITT
                Called Party Number i = 0xC1, '0724753'
                                Plan:ISDN, Type:Subscriber(local)
109706: Nov  5 20:20:35: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x82A2
109707: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109708: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_digit_end:
109709: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_insert_call_active_entry:
109710: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_incr_if_call_volume:
109711: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_call_disconnected:
   Cause Value=100, Interface=0x22F9DCD0, Call Id=3770
109712: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_call_disconnected:
109713: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallReleaseResources:
109714: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=3770
109715: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallDisconnect:
109716: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallDisconnect:
109717: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallDisconnect:
109718: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallDisconnect:
109719: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallDisconnect:
109720: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_get_transfer_info:
109721: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_get_transfer_info:
109722: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_insert_call_history:
109723: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccGetCallActiveByCallID:
109724: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccGetCallActiveByCallID:exit@12848
109725: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22F9DCD0, Tag=0x0, Call Id=3770,
109726: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_disconnect_notify:
109727: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/callStackPop:exit@5101
109728: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_api_call_disconnect_done:
109729: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
109730: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_delete_guid_pod_entry:exit@1206
109731: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109732: Nov  5 20:20:35: :cc_free_feature_vsa freeing 3DBD4060
109733: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109734: Nov  5 20:20:35:  vsacount in free is 1
109735: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_delete_call_entry:
109736: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x3B7A145C]
109737: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=3770
109738: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallGetVoipFlag:
   Flag=FALSE
109739: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=3770
109740: Nov  5 20:20:35: //3770/06402BBF9DC1/CCAPI/ccCallSetVoipFlag:
109741: Nov  5 20:20:35: //3770/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109742: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/ccGetCallGCID:
109743: Nov  5 20:20:35: //3770/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109744: Nov  5 20:20:35: //-1/xxxxxxxxxxxx/CCAPI/ccSetCallGCID:
109745: Nov  5 20:20:35: //3770/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109746: Nov  5 20:20:35: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109747: Nov  5 20:20:35: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
109748: Nov  5 20:20:35: //3770/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109749: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallDisconnect:
109750: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallDisconnect:
109751: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallDisconnect:
109752: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/ccCallDisconnect:
att-madison1-vgw#
109753: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_get_transfer_info:
109754: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_get_transfer_info:
109755: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
109756: Nov  5 20:20:35: //3769/06402BBF9DC1/CCAPI/cc_api_call_disc_cause_update:
att-madison1-vgw#
109757: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_api_insert_call_history:
109758: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/ccGetCallActiveByCallID:
109759: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/ccGetCallActiveByCallID:exit@12848
109760: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x41ABA830, Tag=0x0, Call Id=3769,
109761: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_disconnect_notify:
109762: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/callStackPop:exit@5101
109763: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_api_call_disconnect_done:
109764: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
109765: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_delete_guid_pod_entry:exit@1206
109766: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_delete_call_entry:
   Raw Message=0x41A69C84
109767: Nov  5 20:20:41: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109768: Nov  5 20:20:41: :cc_free_feature_vsa freeing 3DBD3EA0
109769: Nov  5 20:20:41: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
109770: Nov  5 20:20:41:  vsacount in free is 0
109771: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_delete_call_entry:
109772: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_delete_call_entry:
   Total Call Count=0
109773: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x3B7A0214]
109774: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=3769
109775: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/ccCallGetVoipFlag:
   Flag=FALSE
109776: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=3769
att-madison1-vgw#
109777: Nov  5 20:20:41: //3769/06402BBF9DC1/CCAPI/ccCallSetVoipFlag:
109778: Nov  5 20:20:41: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
109779: Nov  5 20:20:41: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
att-madison1-vgw#
109780: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=13205987631, Called Number=, Voice-Interface=0x41ABA830,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
109781: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=200
109782: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
109783: Nov  5 20:21:03: //-1/1971847E9DC6/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=13205987631
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
109784: Nov  5 20:21:03: //-1/1971847E9DC6/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x41ABA830, Call Info(
   Calling Number=13205987631,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=200, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
109785: Nov  5 20:21:03: //-1/1971847E9DC6/CCAPI/cc_api_call_setup_ind_common:
   Interface Type=3, Protocol=0
109786: Nov  5 20:21:03: //-1/1971847E9DC6/CCAPI/ccCheckClipClir:
   In: Calling Number=13205987631(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
109787: Nov  5 20:21:03: //-1/1971847E9DC6/CCAPI/ccCheckClipClir:
   Calling Party Number Is User Provided
109788: Nov  5 20:21:03: //-1/1971847E9DC6/CCAPI/ccCheckClipClir:
   Out: Calling Number=13205987631(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
109789: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109790: Nov  5 20:21:03: :cc_get_feature_vsa malloc success
109791: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109792: Nov  5 20:21:03:  cc_get_feature_vsa count is 1
109793: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
109794: Nov  5 20:21:03: :FEATURE_VSA attributes are: feature_name:0,feature_time:1035812520,feature_id:3771
109795: Nov  5 20:21:03: //3771/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
109796: Nov  5 20:21:03: //3771/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1
109797: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_init_call_entry:
   call_init_entry calle is 42AB92A8,callid is 3771
109798: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_init_call_entry:
109799: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=3771
109800: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=13205987631(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
109801: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_insert_call_active_entry:
109802: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_incr_if_call_volume:
109803: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_process_call_setup_ind:
   Event=0x41A64150
109804: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=, Call Transfer Consult Id=
109805: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
109806: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
109807: Nov  5 20:21:03: Comparing SSOpCode; 0x50 and 0x0
109808: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
109809: Nov  5 20:21:03: Comparing SSOpCode; 0x12 and 0x0
109810: Nov  5 20:21:03: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   No Matching Node
109811: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccCallSetContext:
   Context=0x3A48F8E0
109812: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 3771 with tag 200 to app "_ManagedAppProcess_Default"
109813: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccCallSetupAck:
   Call Id=3771
109814: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
109815: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_set_transfer_info:
   Call Transfer Reset
109816: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=3771
109817: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
109818: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
109819: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccCallReportDigits:
   (callID=0xEBB, digit_event=0x1, enable=TRUE, consume=FALSE)
109820: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=3771
att-madison1-vgw#
109821: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x41ABA830, callID=0xEBB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
109822: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x41ABA830, Call Id=3771
109823: Nov  5 20:21:03: //3771/1971847E9DC6/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
att-madison1-vgw#
109824: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_begin:
109825: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3771, Digit=5, DigitBeginFlags=0x1,
   Rtp Timestamp=0x715E084F, Rtp Expiration=0x0
109826: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
109827: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
   Source Call Id=3771, Digit=5, Duration=112,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
109828: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
109829: Nov  5 20:21:05: //-1/1971847E9DC6/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=5, Peer Info Type=DIALPEER_INFO_SPEECH
109830: Nov  5 20:21:05: //-1/1971847E9DC6/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=5
109831: Nov  5 20:21:05: //-1/1971847E9DC6/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
109832: Nov  5 20:21:05: //-1/1971847E9DC6/DPM/dpMatchSafModulePlugin:
   dialstring=5, saf_enabled=1, saf_dndb_lookup=0, dp_result=-1
109833: Nov  5 20:21:05: //-1/1971847E9DC6/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
109834: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallActiveUpdateNumbers:
109835: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallReportDigits:
   (callID=0xEBB, digit_event=0x0, enable=FALSE, consume=FALSE)
109836: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallReportDigits:
109837: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x41ABA830, callID=0xEBB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
109838: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_report_digits_done:
109839: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_report_digits_done:
109840: Nov  5 20:21:05: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
109841: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
109842: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallDisconnect:
109843: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Disconnect Cause=0)
att-madison1-vgw#
109844: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
109845: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_get_transfer_info:
109846: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_get_transfer_info:
109847: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
109848: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_disc_cause_update:
109849: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
109850: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
att-madison1-vgw#
109851: Nov  5 20:21:05: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
109852: Nov  5 20:21:06: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
109853: Nov  5 20:21:06: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
109854: Nov  5 20:21:06: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end:
att-madison1-vgw#
109855: Nov  5 20:21:07: //3771/1971847E9DC6/CCAPI/cc_api_call_digit_end
Community Member
Share your configand the
Share your config
and the scenario you have, like is it CUCME or CUCM
VG is it MGCP or SCCP
Community Member
CUCM and GW is H.323 --More--
 --More--         no ipv6 cef
 --More--         multilink bundle-name authenticated
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         isdn switch-type primary-ni
 --More--         !
 --More--         !
 --More--         !
 --More--         voice-card 0
 --More--          dspfarm
 --More--          dsp services dspfarm
 --More--         !
 --More--         !
 --More--         voice call send-alert
 --More--         voice rtp send-recv
 --More--         !
 --More--         voice service pots
 --More--          fax rate disable
 --More--         !
 --More--         voice service voip
 --More--          no ip address trusted authenticate
 --More--          allow-connections h323 to h323
 --More--          allow-connections h323 to sip
 --More--          fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 --More--          h323
 --More--           no h225 timeout keepalive
 --More--          modem passthrough nse codec g711ulaw redundancy
 --More--         !
 --More--         voice class codec 1
 --More--          codec preference 1 g711ulaw
 --More--          codec preference 2 g729r8
 --More--         !
 --More--         voice class h323 1
 --More--           h225 timeout tcp establish 3
 --More--           call preserve
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         voice translation-rule 10
 --More--          rule 1 /^\(700.\)/ /1320598\1/
 --More--          rule 2 /^\(701[0-7]\)/ /1320598\1/
 --More--          rule 3 /^\(7631\)/ /1320598\1/
 --More--          rule 4 /^\(7351\)/ /1320598\1/
 --More--          rule 5 /^\(2...\)/ /991826\1/
 --More--         !
 --More--         voice translation-rule 20
 --More--          rule 1 /^9918262.../ /3205987351/
 --More--         !
 --More--         voice translation-rule 30
 --More--          rule 1 /^.*\(....\)/ /\1/
 --More--         !
 --More--         !
 --More--         voice translation-profile Expand-DID
 --More--          translate calling 10
 --More--          translate called 10
 --More--         !
 --More--         voice translation-profile Out-NONDID
 --More--          translate calling 20
 --More--         !
 --More--         voice translation-profile STRIPTO4
 --More--          translate called 30
 --More--         !
 --More--         voice translation-profile stripto4
 --More--         !
 --More--         !
 --More--         !
 --More--         fax send max-speed 9600
 --More--         license udi pid CISCO2921/K9 sn FTX1833AHCX
 --More--         hw-module pvdm 0/0
 --More--         !
 --More--         hw-module pvdm 0/1
 --More--         !
 --More--         hw-module pvdm 0/2
 --More--         !
 --More--         !
 --More--         !
 --More--         archive
 --More--          log config
 --More--           logging enable
 --More--           logging size 500
 --More--           notify syslog contenttype plaintext
 --More--           hidekeys
 --More--          path flash:config-backup
 --More--          maximum 14
 --More--          write-memory
 --More--          time-period 43200
 --More--         username cargill privilege 15 secret 5
 --More--         !
 --More--         redundancy
 --More--         !
 --More--         !
 --More--         controller T1 0/0/0
 --More--          fdl both
 --More--          clock source line independent
 --More--          cablelength long 0db
 --More--          channel-group 0 timeslots 1-24
 --More--          description ---> This is an ATT T1 circuit
 --More--         !
 --More--         controller T1 0/1/0
 --More--          fdl both
 --More--          pri-group timeslots 1-24
 --More--          description T1/PRI Frontier
 --More--         !
 --More--         ip tftp source-interface Loopback0
 --More--         ip ssh version 2
 --More--         ip scp server enable
 --More--         !
 --More--         class-map match-any set-interactive-28
 --More--           description interactive app exception queue
 --More--          match access-group 2028
 --More--         class-map match-any set-interactive-26
 --More--           description WTS and Telnet app queue
 --More--          match access-group 2026
 --More--         class-map match-any realtime
 --More--           description RTP Voice queue
 --More--          match ip dscp ef
 --More--          match access-group 2046
 --More--          match ip dscp cs5
 --More--         class-map match-any bulk
 --More--          match ip dscp af11
 --More--          match ip dscp af12
 --More--         class-map match-any burstylo
 --More--          match ip dscp af21
 --More--          match ip dscp af22
 --More--          match ip dscp default
 --More--         class-map match-any burstyhi
 --More--          match ip dscp af31
 --More--          match ip dscp af32
 --More--          match ip dscp cs2
 --More--          match ip dscp cs3
 --More--          match ip dscp cs6
 --More--          match ip dscp cs7
 --More--         class-map match-any responsive
 --More--          match ip dscp af23
 --More--         class-map match-any set-network
 --More--          match access-group 2016
 --More--         class-map match-any call-signal
 --More--         class-map match-any set-scavenger
 --More--          match access-group 2008
 --More--         class-map match-any set-policed
 --More--          match access-group 2034
 --More--         class-map match-any set-voice
 --More--         class-map match-any scavenger-COS5
 --More--          match ip dscp af13
 --More--          match ip dscp cs1
 --More--         class-map match-any burstylo-COS3
 --More--         class-map match-any burstyhi-COS2
 --More--          match ip dscp af33
 --More--         class-map match-any policed-COS2V
 --More--          match ip dscp af41
 --More--          match ip dscp af42
 --More--          match ip dscp af43
 --More--          match ip dscp cs4
 --More--         class-map match-any set-bulk-10
 --More--          match access-group 2010
 --More--         class-map match-any voice
 --More--         class-map match-any set-responsive-18
 --More--           description HTTP, HTTPS and printing queue
 --More--          match access-group 2018
 --More--         class-map match-any set-bulk-14
 --More--          match access-group 2014
 --More--         class-map match-any set-responsive-20
 --More--           description responsive app exception queue
 --More--          match access-group 2020
 --More--         class-map match-any set-call-signal
 --More--           description Call Signaling queue
 --More--          match access-group 2024
 --More--         class-map match-any network
 --More--         !
 --More--         policy-map classify-v1.4
 --More--          class set-scavenger
 --More--           set ip dscp cs1
 --More--          class set-voice
 --More--           set ip dscp ef
 --More--          class set-call-signal
 --More--           set ip dscp cs3
 --More--          class set-interactive-26
 --More--           set ip dscp af31
 --More--          class set-interactive-28
 --More--           set ip dscp af32
 --More--          class set-responsive-18
 --More--           set ip dscp af21
 --More--          class set-responsive-20
 --More--           set ip dscp af22
 --More--          class set-network
 --More--           set ip dscp cs2
 --More--          class set-bulk-10
 --More--           set ip dscp af11
 --More--          class set-bulk-14
 --More--           set ip dscp af12
 --More--          class set-policed
 --More--           set ip dscp af41
 --More--          class class-default
 --More--           set ip dscp default
 --More--         policy-map at&tmpls-schedule-v2.0
 --More--          class realtime
 --More--           priority percent 40
 --More--          class policed-COS2V
 --More--           bandwidth remaining percent 10
 --More--          class burstyhi-COS2
 --More--           bandwidth remaining percent 40
 --More--          class burstylo-COS3
 --More--           bandwidth remaining percent 20
 --More--          class scavenger-COS5
 --More--           bandwidth remaining percent 5
 --More--           bandwidth remaining percent 25
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         interface Loopback0
 --More--          description ---> att-madison1-vgw loopback 0
 --More--          ip address X.X.X.X 255.255.255.255
 --More--          no ip proxy-arp
 --More--          ip flow ingress
 --More--          h323-gateway voip interface
 --More--          h323-gateway voip bind srcaddr X.X.X.X
 --More--         !
 --More--         interface Embedded-Service-Engine0/0
 --More--          shutdown
 --More--         !
 --More--         !
 --More--         interface Serial0/1/0:23
 --More--          description T1/PRI Frontier 23HCGS570177CZUC
 --More--          encapsulation hdlc
 --More--          isdn incoming-voice voice
 --More--          isdn map address ^011* plan unknown type unknown
 --More--          no cdp enable
 --More--         !
 --More--         !
 --More--         !
  --More--         !
 --More--         !
 --More--         !
 --More--         control-plane
 --More--         !
 --More--         !
 --More--         voice-port 0/1/0:23
 --More--          translation-profile incoming STRIPTO4
 --More--          translation-profile outgoing Out-NONDID
 --More--         !
 --More--         voice-port 0/2/0
 --More--          description FXS dn =  13205987631 Main Fax
 --More--          station-id name MainFax
 --More--          station-id number 13205987631
 --More--          caller-id enable
 --More--         !
 --More--         voice-port 0/2/1
 --More--         !
 --More--         voice-port 0/2/2
 --More--         !
 --More--         voice-port 0/2/3
 --More--          !
 --More--          !
 --More--          !
 --More--         !
 --More--         !
 --More--         !
 --More--         mgcp profile default
 --More--         !
 --More--         sccp local Loopback0
 --More--         sccp ccm X.X.X.X identifier 2 version 7.0
 --More--         sccp ccm X.X.X.X identifier 1 version 7.0
 --More--         sccp ip precedence 3
 --More--         sccp
 --More--         !
 --More--         sccp ccm group 18261
 --More--          bind interface Loopback0
 --More--          associate ccm 1 priority 1
 --More--          associate ccm 2 priority 2
 --More--          associate profile 20 register MTP_S1826_GW1
 --More--          associate profile 10 register CFB_S1826_GW1
 --More--          keepalive retries 5
 --More--         !
 --More--         dspfarm profile 20 transcode
 --More--          codec g729r8
 --More--          codec g711ulaw
 --More--          codec g711alaw
 --More--          codec g729ar8
 --More--          codec g729abr8
 --More--          maximum sessions 10
 --More--          associate application SCCP
 --More--         !
 --More--         dspfarm profile 10 conference
 --More--          codec g729br8
 --More--          maximum sessions 5
 --More--         !
 --More--         dial-peer voice 1 pots
 --More--          description Incoming calls LEC PRI
 --More--          incoming called-number .T
 --More--          direct-inward-dial
 --More--          port 0/1/0:23
 --More--          forward-digits all
 --More--         !
 --More--         dial-peer voice 200 pots
 --More--          destination-pattern 13205987631
 --More--          port 0/2/0
 --More--         !
 --More--         dial-peer voice 1001 voip
 --More--          description Peer NACH01 Subscriber H
 --More--          preference 1
 --More--          destination-pattern 700.
 --More--          progress_ind setup enable 3
 --More--          session target ipv4:X.X.X.X
 --More--          voice-class codec 1
 --More--          voice-class h323 1
 --More--          dtmf-relay cisco-rtp h245-signal h245-alphanumeric
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1002 voip
 --More--          description Peer NACH01 Subscriber F
 --More--          preference 2
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1003 voip
 --More--          destination-pattern 2...
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1004 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1005 voip
 --More--          description SRST mode
 --More--          translation-profile incoming Expand-DID
 --More--          translation-profile outgoing Expand-DID
 --More--          preference 4
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1006 voip
 --More--          preference 3
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1011 voip
 --More--          destination-pattern 701[0-7]
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1012 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1015 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1021 voip
 --More--          destination-pattern 7631
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1022 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1023 voip
 --More--          destination-pattern 7351
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1024 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1025 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 1026 voip
 --More--          no vad
 --More--         !
 --More--         dial-peer voice 2001 pots
 --More--          description E911 Emergency  Service
 --More--          destination-pattern 911
 --More--          prefix 911
 --More--         !
 --More--         dial-peer voice 2002 pots
 --More--          destination-pattern 8911
 --More--          prefix 911
 --More--         !
 --More--         dial-peer voice 2007 pots
 --More--          description 8N11 Non-Emergency  Services
 --More--          destination-pattern 8[2345678]11
 --More--          forward-digits 3
 --More--         !
 --More--         dial-peer voice 3003 pots
 --More--          description 10 digit local calling
 --More--          destination-pattern 8[2-9]..[2-9]......
 --More--          forward-digits 10
 --More--         !
 --More--         dial-peer voice 4001 pots
 --More--          description 11 digit Long distance
 --More--          destination-pattern 81[2-9]..[2-9]......
 --More--          prefix 1
 --More--         !
 --More--         dial-peer voice 4002 pots
 --More--          description International Calls
 --More--          destination-pattern 8011T
 --More--          prefix 011
 --More--         !
 --More--         dial-peer voice 5001 pots
 --More--          description 888 Toll Free Calls
 --More--          destination-pattern 81888.......
 --More--          prefix 1888
 --More--         !
 --More--         dial-peer voice 5002 pots
 --More--          description 877 Toll Calls
 --More--          destination-pattern 81877.......
 --More--          prefix 1877
 --More--         !
 --More--         dial-peer voice 5003 pots
 --More--          description 866 Toll Free Calls
 --More--          destination-pattern 81866.......
 --More--          prefix 1866
 --More--         !
 --More--         dial-peer voice 5004 pots
 --More--          description 855 Toll Free Calls
 --More--          destination-pattern 81855.......
 --More--          prefix 1855
 --More--         !
 --More--         dial-peer voice 5005 pots
 --More--          description 800 Toll Free Calls
 --More--          destination-pattern 81800.......
 --More--          prefix 1800
 --More--         !
 --More--         dial-peer voice 5006 pots
 --More--          description 844 Toll Free Calls
 --More--          destination-pattern 81844.......
 --More--          prefix 1844
 --More--         !
 --More--         dial-peer voice 3001 pots
 --More--          description 7 digit local calling Pots
 --More--          destination-pattern 8[2-9]......
 --More--          forward-digits 7
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         gatekeeper
 --More--          shutdown
 --More--         !
 --More--         !
 --More--         call-manager-fallback
 --More--          secondary-dialtone 8
 --More--          max-conferences 8 gain -6
 --More--          transfer-system full-consult
 --More--          timeouts interdigit 5
 --More--          ip source-address X.X.X.X port 2000
 --More--          max-ephones 48
 --More--          max-dn 96 dual-line
 --More--          after-hours block pattern 1 8411 7-24
 --More--          after-hours block pattern 2 81900....... 7-24
 --More--          after-hours block pattern 3 81700....... 7-24
 --More--          after-hours block pattern 4 81976....... 7-24
 --More--          after-hours block pattern 5 8976....... 7-24
 --More--          after-hours block pattern 6 81...976.... 7-24
 --More--          after-hours block pattern 7 85551212 7-24
 --More--          after-hours block pattern 8 81...5551212 7-24
 --More--          transfer-pattern .T
Can you post a debug isdn
Can you post a debug isdn q931 of a working call? Looks like the caller-id starts with 1 and that might be why?
Please rate useful posts.
I agree with George, you may
I agree with George, you may need to strip the "1" from your ANI.
85
