fax over fxs/fxo
hello does the regular fxo/fxs dial-peer configuration configuration will allow us to fax without the need additional config? example configuration from you are welcome. tx :)
Hall of Fame Super Gold
Re: fax over fxs/fxo
Yes, no additional configuration is necessary.
yup. tx for reply. i forgot to inform you that i use vad option and low bandwidth codec. so far my fax transmission is unsucessful. i am afraid to make changes that could make impact on the network performance. my question is does the codec could make the fax disabled? or it is the vad? tx
do you have fxo/fxs in the same router ? In this case, there is no vad neither codec. The only thing you can try is adjusting the fxo impedance arccording to the following document:
http://cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080477a06.shtml
As a courtesy to those providing answers, please rate all useful posts
185
