Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Fax over IP... confused!
Hi guys,
I'm very confused about how fax relay works in a Cisco VoIP environment. I've read all the documents I could find, but questions remains.
Do I have to apply the directives on a dial-peer with the destination-pattern set as the fax extension number ?
Or does the system automatically detects if the call is a voice call or a fax call ?
In fact, I don't quite understand how I can define what devices should use fax relay (cisco protocol, not t38)
Here's an example of what I've done so far.
37002 is the extension number of a fax in a remote office.
dial-peer voice 37002 voip
destination-pattern 37002
fax-relay ecm disable
fax-relay sg3-to-g3
fax protocol cisco
Is that right ?
Thanks !
Re: Fax over IP... confused!
you may want to add the ip address of the remote gateway you are sending to under the dial-peer
session target ipv4: [ip address of remote gateway]
The dial-peer not detected which device delivery the call
You have insert the destination for each device
for example:
dial-peer voice 1234 voip
destination-pattern 1234
session target ipv4: 192.168.1.1
or
dial-peer voice 1234 pots
voice-port 0/0/0
do you understand?
114
