Fax prblem in UC500
mdwasim415
I have connected the fax device on the FXS port. The phone keeps ringing but the fax doesn't start and we are not able to receive faxes but can send them. We just have one PSTN line.
Can anyone help on this
Borkes1985
seems, faxes don't pass handshaking state.
tell us what fax protocol you use (statement in voice service voip) and your fxo and fxs voice-port settings.
Hello there,
I am attaching teh config for your refrence.
Thanks for your reply.
couldnt find out what is the dial-peer pointing to your fax machine? you have only 9T peers. And what is your fax extension?
for example #299
voice service voip
fax protocol pass-through g711ulaw
dial-peer voice 6 pots
destination-pattern 299
port 0/0/0 (where fax is attached)
fax rate 14400
voice-port 0/0/0 (fxs port)
no echo-cancel enable
descriptio FAX
The fax machine is attached on the FXS voice port 0/0/0 with extension 301.
I'll try this config n get back to you thanks alot my freind.
