Fax Problems using Pri-T1 on VG-224 Gateway
Hello Everyone,
   I'am having a problem with faxing out... I can fax to some numbers just fine and others I can't.. Does anyone know what could be causing this?  I'am using T.38 fax relay in my Call Manager programming...
1 REPLY
Have you verified the CSS assigned to the VG224? Also have you attempted calling the FAX numbers in question, to make sure that the issue isn't on their end.
Yosh
HTH Regards, Yosh
81
