Fax Relay AS 5300
I'm having problems completing fax calls. I have these dialpeers configured:
dial-peer voice 9999 voip
incoming called-number #1..........
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol t38 ls-redundancy 5 hs-redundancy 0 fallback none
no vad
dial-peer voice 1111 pots
tone ringback alert-no-PI
destination-pattern #1..........
progress_ind setup enable 3
forward-digits 10
This is the output of command: debug fax relay t30 all-level-1
Oct 1 20:53:00.569: 2:D (1327887) 1197092002 fr-entered (10ms)
Oct 1 20:53:01.274: 2:D (1327887) 1197092708 fr-msg-det NSF
Oct 1 20:53:02.184: 2:D (1327887) 1197093618 fr-msg-det NSF
Oct 1 20:53:02.877: 2:D (1327887) 1197094308 fr-msg-det CSI
Oct 1 20:53:03.598: 2:D (1327887) 1197095028 fr-msg-det DIS
Oct 1 20:53:08.306: 2:D (1327887) 1197099728 fr-msg-det NSF
Oct 1 20:53:09.215: 2:D (1327887) 1197100638 fr-msg-det NSF
Oct 1 20:53:09.908: 2:D (1327887) 1197101328 fr-msg-det CSI
Oct 1 20:53:10.629: 2:D (1327887) 1197102048 fr-msg-det DIS
Oct 1 20:53:17.517: 2:D (1327887) 1197108928 fr-msg-det NSF
Oct 1 20:53:18.418: 2:D (1327887) 1197109828 fr-msg-det NSF
Oct 1 20:53:19.119: 2:D (1327887) 1197110528 fr-msg-det CSI
Oct 1 20:53:19.840: 2:D (1327887) 1197111248 fr-msg-det DIS
Oct 1 20:53:26.732: 2:D (1327887) 1197118128 fr-msg-det NSF
Oct 1 20:53:27.633: 2:D (1327887) 1197119028 fr-msg-det NSF
Oct 1 20:53:28.334: 2:D (1327887) 1197119728 fr-msg-det CSI
Oct 1 20:53:29.056: 2:D (1327887) 1197120448 fr-msg-det DIS
Oct 1 20:53:32.413: 2:D (1327887) 1197123798 fr-msg-det DCN
Oct 1 20:53:33.102: 2:D (1327887) 1197124488 fr-pkt-loss 9
What seems to be the problem?
Thanks in advance.
Regards.
GH
1 REPLY
Re: Fax Relay AS 5300
The originating fax machine doesn't appear to be responding with a DCS.
Not sure why - fax machine are odd creatures.
-nick
149
