Fax relay problem
I am trying to connect to line no. 0294374778. The router is establishing the call but it will last only 60 seconds. Our router is receiving a disconnect message from other end. (FYI earlier our router was sending the disconnect message to the far end). Please find enclosed the output from debug isdn931 and show run.
For your information I am tyring to send a fax to the number listed above and the dial peer configuration of our router is as below. Could you please let me know whether the configuration is fine
dial-peer voice 11 voip
huntstop
voice-class codec 1
session protocol sipv2
incoming called-number .T
fax-relay ecm disable
fax rate disable
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
no vad
FYI the call is using the above dial peer. Just another piece of information in our office the fax is connected to the modem and the modem is connected to a satellite dish. At the other end the call is going from the dish to the PSTN. I can hear tones on faxes on both end.
1 ACCEPTED SOLUTION
Re: Fax relay problem
If you are trying to use T.38 Fax Relay, then you need to replace the command "fax rate disable" with "fax rate 7200". Try this config.
dtmf-relay h245-alphanumeric
fax rate 7200
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
You should also remove the "voice-class codec" from your faxing dial-peers, and you must make sure that BOTH ENDS have the same configuration on the dial-peers in use.
1 REPLY
fax rate 7200
no vad
180
