Community Member
Fax services with CME and CUE.
Anyone knows it the cme and cue are able to receive fax over ip without an aditional product?
Im looking a solution (reception only) for cisco cme and cue.
There is a solution using tcl (on/off ramp) but it works only for FXO ports. I want implement something similar
but I have a SIP trunk.
Thanks.
Community Member
any idea?
VIP Super Bronze
Have you got fxs cards on your voice gateway. You can connect your fax machine to fxs cards and that should work. Otherwise you will need to use a 3rd party fax solution.
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
209
