FAX store and forward on ISR routers?
webstd.design
Can I configure FAX over IP - SMTP function on ISR routers? Not AS5XXX
Thank you!
6 Replies 6
webstd.design
Here
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_fax_services_over_ip_application_guide/t37.html
mentions AS5300 but I really didn't understand can I use ISR routers.
Thank you!
Any answer?
could you please elaborate what you wanto achieve?
I have router ISR 3825.
I want to know - could I use this router ot send/receive FAXes ot mail-box and vice-versa
Do you want to use the Fax Relay option (T.38 or Cisco Fax Relay) or Fax Passthrough (I presume its Fax Relay you want).
Yes, thats possible on any ISRs (provided you have FXS cards), as far as I have checked I guess the SRND would be helpful:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/gateways.html#wp1047198
Hope that helps,
Kindly Rate if it does help
Wilson Samuel
