Community Member
Fax Store and Forward T.37 conf issue
Dear friends,
I have tried to configure the on-ramp configuration so to sum up my needs:
I want to receive a fax message on email address only (no sending faxs) so i have plug in my fax line into an FXO port and i type in the following configuration:
ip domain name dot.com
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server X.X.X.X port 25
mta send subject "Fax From 71942460"
mta send origin-prefix FAX
mta send postmaster postmaster@dot.com
mta send mail-from hostname Seifeddine@dot.com
mta send mail-from username $s$
mta send return-receipt-to username $s$
service onramp flash:app_faxmail_onramp.2.0.0.0.tcl
service fax_detect flash:app_fax_detect.2.1.2.2.tcl
dial-peer voice 71942 pots
service onramp
incoming called-number 0021674123123
direct-inward-dial
dial-peer voice 646 mmoip
service onramp out-bound
max-conn 48
information-type fax
session target mailto:Seifeddine@dot.com
image encoding MH
image resolution fine
mdn
dsn success
dsn failure
So when i'm trying to send fax msg from a fax machine i get a busy tone each time so can anyone help to figure this thing out thanks in advance
1 REPLY
Anonymous
N/A
Re: Fax Store and Forward T.37 conf issue
When acting as the on-ramp gateway, the Cisco gateway receives faxes from end users, converts them into TIFF files, creates standard MIME e-mail messages, attaches the TIFF files to the e-mail messages, and forwards the fax-mail messages to the designated SMTP server for storage.
The gateway uses the sending MTA and dial peers to complete these tasks. The sending MTA, which is the Cisco gateway, defines delivery parameters associated with the e-mail message to which the fax TIFF file is attached. The delivery parameters include defining a return e-mail path or designating a destination mail server.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/plfxrl26.html#wp1119150
126
