01-20-2011 07:08 PM - edited 03-16-2019 03:00 AM
Hello Everyone,
This is slightly off-topic. I was wondering if anyone had any any recommendations for a software or hardware package that will allow inbound faxes to get routed to a network folder instead of being printed out. A"plus" would be the ability to fax outbound from the desktop as well.
Thanks in advance! All replies rated
Solved! Go to Solution.
01-20-2011 08:16 PM
A multitech fax server will do the job, you just need analog stations to plug in the fax server. Depending on the number of concurrent faxes will determine the size of fax server you need. They have a light weight client that will appear as a printer and you can print to fax and enter your destination.
01-20-2011 08:16 PM
01-20-2011 11:03 PM
Using T.37 onramp you can receive faxes to a public folder in exchange that has an email address associated with it.
I am not sure about a network folder
01-21-2011 07:01 AM
Thanks. Just what I needed!
