Fax tone stops on Exacom E&M-200SF integration
I'm connecting 2 VIC2-2E/M on a 3662 with an Exacom E&M-200SF (http://www.exacom.com/html/products/E&M200sf.htm)
and I'm enabling the signaling on Type I and 4-wire operation.
The Exacom device is connected with a Castelle Fax Server.
The call starts ok, but the fax tone stops app 10 seconds since the calls started.
The route call is this:
PSTN > E1 MGCP 2821 > CCM 5.1 > H323 3662
The config on gw 3662 is this:
voice service voip
signaling forward none
fax protocol pass-through g711alaw
h323
voice-port 2/0/0
operation 4-wire
signal immediate
input gain 12
output attenuation -4
dial-peer voice 50005 pots
destination-pattern 0525
progress_ind alert enable 8
direct-inward-dial
port 2/0/0
This Exacom has an FXS port to connect the fax server port, so I can connect a phone and call it from an IP Phone without problem.
If anyone has experience with this devices, I'll appreciate the support.
TIA
Andres Pasten Calzada
Silver
Re: Fax tone stops on Exacom E&M-200SF integration
The Cisco 2600 and 3600 series routers and Cisco MC3810 multiservice concentrator gateways provide standards-based toll bypass for fax and voice calls. In addition to existing voice and fax toll bypass capabilities, the multiservice gateways provide toll bypass for fax relay with the standards-based ITU-T T.38 fax relay implementation.
Interoperability with T.37 fax relay for VoIP H.323The Cisco 2600 and 3600 series routers and Cisco MC3810 multiservice concentrator gateways with ITU-T T.38 fax relay capability can interoperate with third-party gateways and gatekeepers over an IP H.323 network. The goal is to work with third-party gateways and gatekeepers to provide ITU-T standards-based T.38 fax relay services for multivendor networks.
Sounds like you are using this device to convert from E&M to FXS for the fax server. This problem sounds like a fax relaty/passthrough issue and is possibly due to the config on the MGCP gateway.
Make sure the MGCP gateway is set up as detailed here -
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008053b50a.html
the important configs are -
ccm manager mgcp
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 10.3.222.1 service-type mgcp version 0.1
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
mgcp fax t38 inhibit
These will force the GW to do a codec upspeed to G711alaw when it detects a fax or modem CNG tone, which will then match what you have configured on the 3662 gateway.
Also, you need some minor corrections on the POTS dial peer -
progress_ind alert enable 8 <--- remove
direct-inward-dial <--- remove
port 2/0/0
These highlighted commands are not needed to analogue ports - they are for ISDN type interfaces.
Yes, the Exacom converts from E&M signaling to teh FXS of the fax server.
I've tested the information in the related link, but including:
mgcp modem passthrough voip redundancy
But the call experienced a significant level of noise, and it didn't solve the problem.
I'll try again with the corrections on the dial-peer pots, and I'll let you know.
Only one question, on the gateway config page on the CCM, i've fax passthrough and modem passthrough enabled, is that ok, or shall I disable modem?
TIA
This is not going to help either -
voice-port 2/0/0
operation 4-wire
signal immediate
input gain 12
the input gain is way too high and setting a -4dB attenuation means you boost the output level as well. This will result in distortion of the signal and could explain the noise you are hearing.
Set both these back to 0 and give it another try.
277
