Fax + VG224
Hi all,
I'm working on that design : Fax -> VG224 configurated with passthrough (SCCP) -> VG 28XX (MGCP).
When I send faxs :
1. I send 10 pages in intern and it's works
2. Sometimes, when I send faxs to external (fax client), it's only working for the first 5 pages and after I have an error.
This is the configuration of the VG:
VG224-1#sh running-config
version 12.4
no service pad
service timestamps log datetime msec localtime
hostname VG224-1
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 4096
no aaa new-model
clock timezone AEST 10
clock summer-time AEDT recurring 1 Sun Oct 2:00 1 Sun Apr 2:00
ip source-route
ip cef
no ip domain lookup
ip multicast-routing
no ipv6 cef
stcapp register capability 2/2 modem-passthrough
stcapp register capability 2/3 modem-passthrough
stcapp ccm-group 1
stcapp
voice service voip
no fax-relay sg3-to-g3
modem passthrough nse codec g711alaw redundancy maximum-sessions 5
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address
ip pim sparse-dense-mode
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 2/0
timeouts ringing infinity
caller-id enable
voice-port 2/1
caller-id enable
voice-port 2/2
caller-id enable
voice-port 2/3
caller-id enable
voice-port 2/4
caller-id enable
voice-port 2/5
caller-id enable
voice-port 2/6
caller-id enable
voice-port 2/7
caller-id enable
voice-port 2/8
timing hookflash-in 200 50
caller-id enable
voice-port 2/9
caller-id enable
voice-port 2/10
caller-id enable
voice-port 2/11
caller-id enable
voice-port 2/12
caller-id enable
voice-port 2/13
caller-id enable
voice-port 2/14
caller-id enable
voice-port 2/15
caller-id enable
voice-port 2/16
caller-id enable
voice-port 2/17
caller-id enable
voice-port 2/18
caller-id enable
voice-port 2/19
caller-id enable
voice-port 2/20
caller-id enable
voice-port 2/21
caller-id enable
voice-port 2/22
caller-id enable
voice-port 2/23
caller-id enable
no ccm-manager fax protocol cisco
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp timer receive-rtcp
mgcp fax rate 14400
mgcp fax t38 inhibit
mgcp behavior g729-variants static-pt
sccp local FastEthernet0/0
sccp ccm 192.168.xx.x identifier 2 version 7.0
sccp ccm 192.168.xx.x identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 500 pots
service stcapp
port 2/0
dial-peer voice 501 pots
service stcapp
port 2/1
dial-peer voice 502 pots
service stcapp
port 2/2
dial-peer voice 503 pots
service stcapp
port 2/3
dial-peer voice 504 pots
service stcapp
port 2/4
dial-peer voice 505 pots
service stcapp
port 2/5
dial-peer voice 506 pots
service stcapp
port 2/6
dial-peer voice 507 pots
service stcapp
port 2/7
dial-peer voice 508 pots
service stcapp
port 2/8
dial-peer voice 509 pots
service stcapp
port 2/9
dial-peer voice 510 pots
service stcapp
port 2/10
dial-peer voice 511 pots
service stcapp
port 2/11
dial-peer voice 512 pots
service stcapp
port 2/12
dial-peer voice 513 pots
service stcapp
port 2/13
dial-peer voice 514 pots
service stcapp
port 2/14
dial-peer voice 515 pots
service stcapp
port 2/15
dial-peer voice 516 pots
service stcapp
port 2/16
dial-peer voice 517 pots
service stcapp
port 2/17
dial-peer voice 518 pots
service stcapp
port 2/18
dial-peer voice 519 pots
service stcapp
port 2/19
dial-peer voice 520 pots
service stcapp
port 2/20
dial-peer voice 521 pots
service stcapp
port 2/21
dial-peer voice 522 pots
service stcapp
port 2/22
dial-peer voice 523 pots
service stcapp
port 2/23
line con 0
line aux 0
line vty 0 4
login local
ntp server 192.168.xx.x
end
Maybe it's a problem with the clock?
Sylvain
Super Bronze
Re: Fax + VG224
If the problem only happens when sending external, I would start by checking the clocking on your outgoing T1/E1 circuits:
Show controllers e1
Or
Show controllers t1
Post back the output...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: Fax + VG224
VG1#show controllers e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  Cablelength is Unknown
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (348 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     9 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     9 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 2 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     44 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     44 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
E1 0/0/1 is up.
  No alarms detected.
  Data in current interval (350 seconds elapsed):
     45 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     45 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Super Bronze
Re: Fax + VG224
OK, you have slips...
Try:
Conf t
Network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
end
clear controllers e1
Then have a look around any other gateways running E1/T1 circuits you have for similar errors and correct those.
Come back to this one in 15 minutes and see if the errors have stopped; and if so, retest your fax.
Be aware that whilst this is a common cause of errors on faxes, lots of other things could be going wrong as well
Aaron
Please rate helpful posts..
Re: Fax + VG224
no more error.
VG1#sh controllers e1
E1 0/0/0 is up.
  No alarms detected.
  Data in current interval (641 seconds elapsed):
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
E1 0/0/1 is up.
  No alarms detected.
I will see Monday if with fax activities it will be still working. Thanks
607
