FaxFinder FF240-IP and CME
I'm trying to setup the faxfinder ff240-ip fax appliance with a ISR 3925 router running call manager express 8.6. The router has a connection to the PSTN using a T1 PRI. The appliance doesn't have a analog port; only RJ45 ethernet. I know it will use SIP for the call control protocol but I'm not sure how to configure CME to be able to route incoming calls to it from the desginated fax numbers. I assume it would require pots and voip dial peers. Has anyone setup this type of fax server or can offer some advice for the CME side of the configuration?
Everyone's tags (2)
524
