Community Member
FAXing out over PRI
I plan to connect a FAX to an FXS port on a UC520 that uses PRI for PSTN access. Our current telcom provider thinks that FAXes over PRI will not work too well or maybe not at all. Any truth to this? What about inbound? Any problem there?
Diego
Re: FAXing out over PRI
I have several customers who fax over a PRI, and I havent heard any major issues. You may have to tweak the configuration to get it to work correctly, but as far as I know, it works fine.
Community Member
Thanks for the info.
Rgds,
Diego
Community Member
I have a small problem with my FAX machine which is connected to FSX port.
The call flow is :
PSTN --E1--> 2811-GW --FXS--> Fax Machine
The problem is unpredictable as sometime the fax works perfectly (sending and receiving) and sometimes it will be cutted means that only half of the page can be send/receive and the rest are blank !!
any idea please ?
regards,
Hall of Fame Super Gold
Please check for slips with "show controllers e1" and add the network-clock-participate and -select commands.
Community Member
i alreday did it. but still the same !
how i troublshoot this issue, debug or somthing !?
thanks
Community Member
I have the same problem ! Is there someone can told me how can I do ? thanks
Whta problem exactly do you have and what type of lines, and how you faxes are connected.
Community Member
fax machine is connected to FXS port on the router. it have a DID number taken from E1 line on the same router.
so the call fllow PSTN->E1 POTS->FXS POTS
The probelm is when sending.reciving the faxs it's not complete, i.e. if the original page was:
line1
line2
line3
line4
line5
will recive the fax link this:
line1
line2
line4
lin5
it's un-predictable behavoir !
im not able to know how we can dubug or fix it !
any help will be appreciated please....
regards,
hasan
Community Member
We use CME on a 2811 and are faxing using an ATA and experienced the same issue. Turns out when we disabled the "G3" feature on the fax machine it fixed everything. We also use this setup through an FXS port without issue.
Likely you do not have network-clock-participate and network-clock-select commands for this circuit. Result are slips that you can see with "show controllers E1". Configure said commands and problme will be resolved.
407
