Community Member
Faxing problem with CME and CUE
Hi to all,
I am having an aggravating issue with a fax application that has stopped working, but had been working for a few years.
I hesitate to post, and have read all the post's I could find including all the links commonly referenced but to no avail.
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a00801fe5d9.shtml
and
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administration/guide/voicemail/fxgatewy.html
-running CME version 7.1 with IOS version  Version 12.4(24)T1
-CUE is running version 7.0
The error I am getting is %LAPP_ON_MSGS-6-LAPP_ON_CAUSE_NO_ESMTP_CONNECT: ESMTP client did not connect or lost connection to remote server
The only thing that has changed is the email server from exchange 2k3 to 2010. I believe this may be the root to the problem, possibly the way the cisco is putting in the mail commands?
Here is my current config for the mail application.
fax interface-type fax-mail
mta send server 172.17.17.2 port 25
mta send with-subject both
mta send mail-from hostname fax-mailer.company.com
mta send mail-from username fax-mailer
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
dial-peer voice 400 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 701[3-8]
information-type fax
session target mailto:$d$@172.17.17.2
dial-peer voice 101 pots
translation-profile incoming profile1
service onramp
incoming called-number 701[3-8]
direct-inward-dial
port 0/0/0:23
Thank you in advance for any help.
Hall of Fame Super Gold
Re: Faxing problem with CME and CUE
Likely a server issue as you indicated.
Please check the server reachability from the router. Has the server config. changed after the upgrade?
Community Member
I have confirmed the server address is correct and reachable, as far as server configuration, I am checking with the admin that upgraded the server.
423
