Faxing with EVM-HD-8FXS/DID
If you have a EVM-HD-8FXS/DID with faxes connected via a breakout panel in one building, and a fibre connection to another building where additional fax machines are located how do you connect them ? Is the ATA the only way to go ? due to the electrical grounding difference ?
1 REPLY
Re: Faxing with EVM-HD-8FXS/DID
I do not know what your are refering to as far as the ground issue but no you cannot extend the FXS ports over fiber they would require a copper pair back to the router that has the module in it. ATA would probably be your best bet.
122
