Feature "Show All Calls on Primary Line"
Stefan Walter
Hi Community,
we're facing some curiosity with the feature - show all calls on primary line.
Just for troubleshooting I recreate an issue - I tested with an CallManager in Version
8.5.1.14900-5. In this Version there was the feature under phones - SIP8961 - Product Specific Configuration Layout available.
Customer is using 8.6.2a -> there is the feature not available.
Can everybody tell me why ? I need this feature.
Thanks for help,
Stefan
Manish Gogna
Hi Stefan,
Installing the latest device pack for 8.6.2 version should fix it. This is related to the following defect
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtt96205
Although the defect status says release pending but the latest device pack should fix this.
Manish
