Feature SRST Router 2911
I have a Cisco Router 2911, and I have these print license FL-SRST, FL-CME-SRST-25, FL-CME-SRST-25 whit the Router, and when I enter the command
show license detail cme-srst and have this output:
Router#show license detail cme-srst
% Error: No license for cme-srst found - License feature not found
And when I enter the command show licence, I dont see the feature cme-srst. How I can enable these features? In the license printed I have not the PAK number?
I appreciate your time and help, thanks.
Router#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: gatekeeper
Index 6 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Router#show license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
uck9                     yes          yes         no             yes      yes
datak9                   yes          yes         no             no       yes
gatekeeper               yes          yes         no             no       yes
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
SNASw                    yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
Hall of Fame Super Gold
Re: Feature SRST Router 2911
conf term
license accept end user agreement
Then you may need a reload.
Thanks Bevilacqua,
I entered the command license accept end user agreement and then I reload the Router.
Router(config)#license accept end user agreement
PLEASE  READ THE  FOLLOWING TERMS  CAREFULLY. INSTALLING THE LICENSE OR
LICENSE  KEY  PROVIDED FOR  ANY CISCO  PRODUCT  FEATURE  OR  USING SUCH
PRODUCT  FEATURE  CONSTITUTES  YOUR  FULL ACCEPTANCE  OF  THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO  BE BOUND
BY ALL THE TERMS SET FORTH HEREIN.
ACCEPT? [yes/no]: yes
Jan  5 11:34:40.299: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
But the output of the commands show license feature , show license  don't show the cme-srst feature.
Any other suggestions? Thanks.
Which version are you using?
The feature may work and just not show.
Paolo:
CISCO2911/K9 Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
That is rommon version, not IOS.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M7, RELEASE SOFTWARE (fc2)
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M7.bin"
Hall of Fame Super Red
Hi Ricardo,
It's quite possible that Cisco has changed their licensing scheme again
The info that Paolo linked and the steps you have performed are what are
required (in the past) to enable cme-srst on the ISR-G2's as shown in the
link below;
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Try sending an email to;
licensing@cisco.com
to see what has changed here.
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Thanks Rob.Huffman and Paolo,
In IOS version 15.0 the feaure cme-srst is part of uck9!!
Hello all,
to insall the license, do this on the router which will make it install everything on the router;
router(config)#telephony-service
accept the agreement.
2292
