Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Feedback on project Off premise extension
I was wondering if someone in the group has ever come across the following scenario.
I would like to order a t1 channalized to the CO and have them mux it for me and run from the co a telephone line. The telephone line will ride a channel on my t1. Now i would like to take it a step further and configure the gateway with h323 dial peers and pointing to callmanager. Wonder if someone here has done that.
Hall of Fame Super Gold
Re: Feedback on project Off premise extension
There is nothing strange about that. It is called integrated access. Part of the T1 is data, part voice. The router supports that fine.
is there any documentation on this
out there
No special documentation that I know, or you can search "integrated T1 access".
However under controller T1 you will configure channel-group for the data timeslots, ds0-group for the voice with the appropriate signaling type. Once this is done, serial and voice ports will be created, and you configure them normally.
This t1 will be configure for voice only no data so configuration might look like
controller T1 5/0
ds0-group 0 timeslots 1
dial-peer voice 1000 pots
destination-pattern 1000
port 5/0:0
Now you mentioned a signialing type how would i know what signaling type to use
do you have examples?
Why not request an ISDN PRI from the CO? If you do that, it comes in channelized already, has a D-Channel for signaling so you have 23 Bearer channels ultimately capable of handling calls if you want to ramp up...
controller T1 0/1/0
clock source internal
pri-group timeslots 1
trunk-group 1 timeslots 1
interface Serial0/1/0:23
no ip address
isdn switch-type primary-dms100 (or whatever your CO switch is expecting)
isdn bchan-number-order descending
no cdp enable
109
