Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Few Incoming calls for CME not working
Hi All
I just configured a CME for Korea location and some of the incoming calls from the PSTN is not reaching. Below is the log. I Also atttached the configuration of my CME. Could anyone look and comment what all changes to be made from my end.
Logs
Mar 11 20:11:00.415: //-1/27BA8EA8800B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=00132499549692
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1221
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 11 20:11:00.415: //-1/27BA8EA8800B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3151DD38, Call Info(
   Calling Number=00132499549692,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1221(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=INBAND(8), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 11 20:11:00.419: //-1/27BA8EA8800B/CCAPI/ccCheckClipClir:
   In: Calling Number=00132499549692(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=00132499549692(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Mar 11 20:11:00.419: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 20:11:00.419: :cc_get_feature_vsa malloc success
Mar 11 20:11:00.419:  cc_get_feature_vsa count is 1
Mar 11 20:11:00.419: :FEATURE_VSA attributes are: feature_name:0,feature_time:1089425936,feature_id:13
Mar 11 20:11:00.419: //13/27BA8EA8800B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=00132499549692(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1221(TON=Subscriber, NPI=ISDN))
Mar 11 20:11:00.419: //13/27BA8EA8800B/CCAPI/cc_process_call_setup_ind:
   Event=0x2C1D2E68
Mar 11 20:11:00.419: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1221
Mar 11 20:11:00.419: //13/27BA8EA8800B/CCAPI/ccCallSetContext:
   Context=0x424CD41C
   >>>>CCAPI handed cid 13 with tag 1 to app "_ManagedAppProcess_Default"
Mar 11 20:11:00.419: //13/27BA8EA8800B/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Mar 11 20:11:00.419: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Mar 11 20:11:00.419: : updating existing feature vsa
Mar 11 20:11:00.419:  feature call basic
Mar 11 20:11:00.419: //13/27BA8EA8800B/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Mar 11 20:11:00.419: //13/27BA8EA8800B/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Mar 11 20:11:00.511: //13/27BA8EA8800B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3151DD38, Tag=0x0, Call Id=13,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 11 20:11:00.511: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 20:11:00.511: :cc_free_feature_vsa freeing 40EF5208
Mar 11 20:11:00.511:  vsacount in free is 0
Prasanth Thomas Abraham
Strange is that, right now i configured the same ephone-dn for a 7965 (button 1:21) phone and it workied !!!
But if I revert again the back ephone-dn for the existing 7952 phone, it not working.
Cause Value=1 is unallocated/unassigned number.
check the config make sure u have pattern for 1221.
thanks,
Vipul Jindal
255
