Filter by IP the Admin access to CUCM 6
For security reason, I'd like only my Administrator lan be able to connect to the CUCM Page. (https://cucm:8443/ccmadmin)
I cannot filter by acl on my router as the port 8443 is also used by the ccmuser page (https://cucm:8443/ccmuser)
Is there a way to do that on CUCM 6 ?
Thanks for your answer
1 REPLY
Re: Filter by IP the Admin access to CUCM 6
You probably cant do it thought ACL because the ccmadin and the ccmuser pages use the same ports.   Even if you changed the port, they still both use the same ports.
You should really use the Application user account security built into CUCM.   Turn on account login failures and you will know if someone is trying to log into the CUCM pages that does not have access.  Usually reports the IP address and usernames tried.  (RTMT)
167
