Find calls to translation patterns
I'm wondering if it's possible to find how many calls are being dialed to a number that's being translated to another number?
I've read some info in the CDR documation that summarized the answer best best with "When you add calling and called party transformations to a route pattern  or translation pattern, CallManager logs the transformed numbers in the  CDRs and renders the transformed numbers on the display of the calling  phone. CallManager does not insert transformations specified on the  route list’s route group details (or applied by a individual egress  gateway) in the CDRs or render them on the calling device."
All that aside are there creative ways to get the quantity of calls to a "pre translated" number?   My cynical side makes me think "Just change the Route Option to blocked and see who squaks," but I'm sure that's only going to work for a few situations.
Here's some specifics about my environment:
CUCM 8.5
Various ISR running MGCP running 12.4.24T, but I'm working on moving to H.323 configured 2901s running 15.2.4
Currently all translation are being done on the CUCM, but if having the 2901s do the translations that's fine too.
TONY
1 ACCEPTED SOLUTION
Hi Tony,
If you are looking at an option to find the calls made to specific translation patterns on cucm, you can use the following method.
Navigate to Cisco Unified Serviceability >> Tools >> CDR Analysis and Reporting
Once the new menu opens up, Go to CDR >> Export CDR.
Export the CDR Dump and Right Click on the CDR link and Save Link as.
This will save it as a text file and you can convert it to CSV which will open in Excel format.
Then you can easily search for calls made to any translation pattern.
Manish
1 REPLY
Hi Tony,
Manish
416
