firewall restriction for cuci moc
Anyone out there tried cuci moc behind a firewall? what specific versions are best suited/stable for it from ASA viewpoint.
Also, input any other suggestions pertaining to this.
Appreciate all help!
1 ACCEPTED SOLUTION
Re: firewall restriction for cuci moc
I'm not sure if this is of value to you or not, but it's worth passing along.  If you're running with a firewall, here are the ports used by the Client Services Framework leveraged by CUCIMOC:
Network Requirements
Table 1     Ports Used for Inbound Traffic by Cisco Unified Client Services Framework
Port
Protocol
How Cisco UC Integration for Microsoft Office Communicator Uses the Port
16384-32766
UDP
Receives Real-Time Transport Protocol (RTP) media streams for audio and video. These ports are configured in Cisco Unified Communications Manager. For more information about device configuration files, see the Cisco Unified Communications Manager System Guide:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
Table 2     Ports Used for Outbound Traffic by Cisco Unified Client Services Framework
Port
Protocol
69
UDP
Connects to the Trivial File Transfer Protocol (TFTP) server to download the TFTP file.
389
TCP
Connects to the LDAP server for contact searches.
2748
TCP
Connects to the CTI gateway, which is the CTIManager component of Cisco Unified Communications Manager.
5060
UDP/TCP
Provides Session Initiation Protocol (SIP) call signalling.
5061
TCP
Provides secure SIP call signalling.
8443
TCP
Connects to the Cisco Unified Communications Manager IP Phone (CCMCIP) server to get a list of currently-assigned devices.
8191
TCP
Connects to the local port to provide Simple Object Access Protocol (SOAP) web services.
16384-32766
UDP
Sends RTP media streams for audio and video.
Table 3     Ports Used By Cisco UC Integration for Microsoft Office Communicator
Port
Protocol
Description
Key Value Name
44441
TCP
Cisco UC Integration for Microsoft Office Communicator listens for requests from the conversation pane on this port.
CUCIMOCTabTcpPort
44442
HTTP
The Cisco UC Integration for Microsoft Office Communicator process, cucimoc.exe, listens for events from Cisco Unified Client Services Framework (CSF) on this port.
CUCIMOCCSFPort
44440
HTTP
Cisco UC Integration for Microsoft Office Communicator listens for requests from the click-to-call feature on this port.
CUCIMOCTabHttpPort
The following link provides more info: http://www.cisco.com/en/US/docs/voice_ip_comm/cucimoc/7_1/english/release/cucimocReleaseNote.html
Hailey
Please rate helpful posts!
1 REPLY
Port
Protocol
16384-32766
UDP
Port
Protocol
69
UDP
389
TCP
2748
TCP
5060
UDP/TCP
5061
TCP
8443
TCP
8191
TCP
16384-32766
UDP
Port
Protocol
Description
Key Value Name
44441
TCP
CUCIMOCTabTcpPort
44442
HTTP
CUCIMOCCSFPort
44440
HTTP
CUCIMOCTabHttpPort
Hailey
570
