Firmware Check on IP Phones
We have lab setup of CUCM 8.6.2 with upgraded firmware of 9.3.1SR2 as device default for ex: 7941 phones. Later we did a service upgrade to CUCM 8.6.2SU3 and the default firmware changed to 9.3.1SR1. After the switchover, the phone registered back successfully but with existing SR2 not with default load of SR1.
my point is,  When a phone boots up, it will check its nvram firmware with default load, If a phone's preloaded firmware is higher than device default, then it won't manually downgrade to default load. Am I right here?
if not, please let me know why it is not automatically downgrading to default load?
//Suresh Please rate all the useful posts.
1 ACCEPTED SOLUTION
VIP Super Bronze
Wrong. The phone will always install the load level CUCM instructs it to. If this didn't occur, one of two things is true:
  1. The XMLDefault.cnf.xml or SIP.cnf.xml file was not regenerated on TFTP for the phone to notice the firmware level change. Apply config on the phone and see if this takes hold.
  2. The load level has been specified on the phone configuration directly which is overriding the cluster default.
Please remember to rate helpful responses and identify helpful or correct answers.
VIP Super Bronze
Hall of Fame Super Red
Hi Suresh,
Just wanted to add a note to the great info from my friend Jonathan
here (+5 "J"!)
Just to add some new fun into things, you now have to watch for
new "Hardware" versions as well. This will also impact the upgrade
& downgrade determinations made by certain phones when they
look to register;
Hardware Updates
The hardware updates improve the compatibility of internal phone components.
The following table lists the updated hardware versions that require this release.
Phone
Hardware Version
Cisco Unified IP Phone 7942G
15.0 and higher
Cisco Unified IP Phone 7962G
15.0 and higher
Cisco Unified IP Phone 7945G
13.0 and higher
Cisco Unified IP Phone 7965G
13.0 and higher
Cisco Unified IP Phone 7975G
12.0 and higher
Phones  manufactured with these hardware versions must run Firmware  Release  9.3(1)SR1 or later. The phone firmware does not allow the phone  to be  downgraded to releases earlier than Release 9.3(1)SR1.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7900_series/firmware/9_3_1SR1/release_notes/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series_chapter_00.html#P790_RF_ND56648A_00
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
Re: Firmware Check on IP Phones
Thanks Jonathan & Rob. Yes, when I hardcoded the load information on the phone config page, they didn't downgrade as expected.
The phone which didn't downgrade the fimrware automatically though it did not have the load information on the config page.
Perhaps as you said, the .cnf.xml file was not regenerated for that one phone on the TFTP server.
229
