Firmware issue on 7960 stuck
I have a phone that is stuck stating tftp file not found.
The files it is looking for are
TFTP Error from 172.16.11.7 requesting CTLSEP0003E3C44D23.tlv : File does not exist
TFTP Error from 172.16.11.7 requesting SEP0003E3C44D23.cnf.xml : File does not exist
TFTP Error from 172.16.11.7 requesting SIP0003E3C44D23.cnf : File does not exist
TFTP Error from 172.16.11.7 requesting MGC0003E3C44D23.cnf : File does not exist
TFTP Error from 172.16.11.7 requesting XMLDefault.cnf.xml : File does not exist
TFTP Error from 172.16.11.7 requesting SIPDefault.cnf : File does not exist
TFTP Error from 172.16.11.7 requesting MGCDefault.cnf : File does not exist
I need to get it back to P00303020214
I have tried to reset back to factory using the 123456789*0# and no luck.
I have changed the OS79XX.TXT file to read P00305000600
Anything I can do to get this phone back online?
1 ACCEPTED SOLUTION
Green
Re: Firmware issue on 7960 stuck
Can you try downloading a newer firmware.
Looks like an older one (unsigned)
Download the latest one in CC0 and update tftp-server flash and load 7960-7940
then recreate cnf-files.
Green
Are you using CCM ?
Which protocol ? (SCCP, SIP, MGCP)
The phone is already configured in CCM db?
Using CCME
Using SCCP
I have deleted it from the database.
Hall of Fame Super Gold
configure an ephone with correct mac and type, factory reset, and if the sccp files per configured load are available on the router, the phone will upgrade.
hope this helps, please rate post if it does!
I added the ephone and mac and then tried the reset
123456789 and so on and same result?
Do again "term mon" and "debug tftp events" and will see which files the phone is requesting but not getting.
4d09h: TFTP: Looking for CTLSEP0003E3C44D23.tlv
4d09h: TFTP: Looking for SEP0003E3C44D23.cnf.xml
4d09h: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 902 for process 71
4d09h: TFTP: Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for process 71
4d09h: TFTP: Looking for P00303020214.loads
4d09h: TFTP: Looking for P00303020214.sbn
Beside this being old firmware, you have not configured tftp-server commands properly as mentioned before. This is the cause of the TFTP request not getting a reply from router (Opened ....)
Phone is stuck with universla application loader and tftp file cannot be found. Below are the lines from the router. I have DHCP pointing at the router using option 150. All other phones work and reboot fine.
tftp-server flash:P00403020214.bin
tftp-server flash:P00305000301.sbn
tftp-server flash:P00303020214.bin
tftp-server flash:S00103020002.bin
tftp-server flash:P00503010100.bin
telephony-service
load 7910 P00403020214
load 7960-7940 P00303020214
Green
I have tried a number of downloads and no luck. Anyone have a link to good firmware code for thsi 7960 on a CCME running
Software Version 12.3(14)T2 / CME 3.3
I don't see the .loads file in tftp-configuration. Until you make all the files correctlu available, you will have problems.
I use 8.0(7) wuth the telecaster phones.
823
