Firmware query
Hi all,
I have 6925 and 9971 IP phone how to update latest firmware on both the ip phone please help and which is the latest firmware?
1 ACCEPTED SOLUTION
VIP Purple
Firmware query
Hi Alex,
You can use the link to download 6945 depending on the Protocol[SIP/SCCP]. there is no 6925 IP phone
You need to have CCOID to download the files.
http://software.cisco.com/download/release.html?mdfid=283655659&flowid=21941&softwareid=282074289&release=9.3(3)SR1&relind=AVAILABLE&rellifecycle=&reltype=latest
for 9971 , u can use the below link
http://software.cisco.com/download/release.html?mdfid=282749264&flowid=5295&softwareid=282074288&release=9.3(4)&relind=AVAILABLE&rellifecycle=&reltype=latest
procedure to upload files is as below:
  1. Using your web browser, login to the Cisco Unified Operating System Administration web page
  2. Under the Software Upgrades menu, select Install/Upgrade.
  3. Fill in the appropriate values in the Software Location section for the file you downloaded above, and click Next.
  4. In the Options/Upgrades drop-down box, select the file you downloaded above, and click Next.
  5. In the File Checksum Details box, verify you have selected the correct firmware and the MD5 has the correct value, click Next.
  6. Check that you received a Success message
After u upload the files in all servers in a cluster, u need to restart TFTP server.Also , read the Release notes of desired firmware.
regds,
aman
Firmware query
Hi Alex
Through
http://software.cisco.com/download/navigator.html?i=!mmd selecti "voice and Unified comminications" -->> "IP Telephony" --> "Unified Communications Endpoints" you can discover the latest firmware for all IP Phone models.
Anyway:
9971: 9.3(4)
6925 = Unrecognized Model
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
VIP Purple
Firmware query
Hi Alex,
regds,
aman
132
