Firmware upgrade path for 7961 phone
I recently upgrade from CCM 4.2.3(sr4b) to CUCM 7.1.5. I have a model 7961 phone that would not take the firmware upgrade. I had to set the phone back to the default factory settings to get the phone to load up to a normal state at all. Right now the phone is on the network but not working. What follows is the firmware info from a working 7961 and the problem phone:
Working 7961
App Load ID    jar41sccp.9-0-2ES2.sbn
Boot Load ID  7961G_64-02070631Amd64megRel.bin
Version           SCCP41.9-0-2SR1S
Non-working 7961
Boot Load ID 7941G_02070629Amd32megREL.bin
I think I need to get the problem phone on the same firmware. The problem is I need to direct it to the firmware versions inbetween the two and step it up to the correct version. Does anyone know a firmware upgrade path that will get me close enough for the phone to take the version the other phones are running on my system?
jon
Re: Firmware upgrade path for 7961 phone
What I mean when I said that the phone was on the network but not working is that the phone loads, gets an IP
but does not register with my call manager.
Hall of Fame Super Red
Hi Jonathan,
You most likely need 8.5(2) as the interim/Mid-point firmware
Cheers!
Rob
Rob is correct, unless you want to load the unsigned 9-0-2 firmware on your call managers instead so you can upgrade directly to 9-0-2.
Hello, is there any documents that describes the upgrade path for ip phones..??
1888
