Firmware upgrade problem
I try to upgrade  ip phones 6921 thought cme.
 I use  CISCO 2921 voice router   Version 15.3(2)T1   CME  9.5
i downloaded   the latest firmware from cisco.com.  cmterm-69xx-sccp.9-4-1-3 which contains the following files
BOOT69xx.0-0-0-14.zz.sgn
DSP69xx.12-4-122-02-121029.zz.sgn
SCCP69xx.9-4-1-3.loads
SCCP69xx.9-4-1-3.zz.sgn
I uploaded  this files to my router`s flash.Then enter the following commands:
tftp-server flash:6921/DSP69xx.12-4-122-02-121029.zz.sgn alias DSP69xx.12-4-122-02-121029.zz.sgn
tftp-server flash:6921/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:6921/SCCP69xx.9-4-1-3.zz.sgn alias SCCP69xx.9-4-1-3.zz.sgn
tftp-server flash:6921/SCCP69xx.9-4-1-3.loads alias SCCP69xx.9-4-1-3.loads
after in telephony-service i entered command
 load 6921 SCCP69xx.9-4-1-3.loads
after it i immediately get the following errors
 LOAD COMMAND MESSAGE: File flash:/BOOT69xx.0-0-0-14.zz not found
 LOAD COMMAND MESSAGE: File flash:/DSP69xx.12-4-122-02-121029.zz not found
 LOAD COMMAND MESSAGE: File flash:/SCCP69xx.9-4-1-3.zz not found
LOAD COMMAND MESSAGE: File flash:/SCCP69xx.9-4-1-3.loads  not found
Updating CNF files
It seems that it is bug .
VIP Purple
Hi,please refer the
please refer the README
http://www.cisco.com/web/software/282074289/107679/cmterm-6921_6941_6961-sccp.9-4-1-3-readme.html
Before using the 9.4(1) SCCP firmware for Cisco Unified IP Phone models 6921, 6941 and 6961 with Cisco Unified CallManager release 7.1.5 and higher, you must install the latest firmware on all Cisco Unified CallManager servers in the cluster. Direct upgrades using signed load files are supported to firmware releases 9.4(1) from 9.x. To upgrade phones from a load with prior to 9.0(2), you need to upgrade to unsigned 9.x SCCP first, then upgrade to 9.4(1).
check if this helps.
regds,
aman
Hi i have  CME not CUCM. and
Hi i have  CME not CUCM. and CME version is 9.5 .
recently i normally ugrated ip phones 6921 to 9.3. ,but while upgrating to 9.4 i got phoblem.
Hi,Can I know how to solved
Can I know how to solved this? Now I face this issues as well. Do you mind to share the solution
Can you show what the
Can you show what the contents of flash actually look like via "show flash" ?
when i  enter show flash: it
when i  enter show flash: it shows we that   all firmware files is in it
379
