Silver
First time with E-1 - need some help
I have not done any E-1 stuff.
We are building a facility in Mexico and I am looking for any docs that can help.
Voice and Data.
What I have so far for the config:
controller E-1 0/0/0
framing NO-CRC4
channel-group 0 timeslots 1-31
for the voice we were just told
channles 1-10
and the "framing" is R2-M <--I have no idea what this is?
Any help in where to look would be great.
also we have a VWIC2-E1/T1 with 2 interfaces on the card. We had to do:
no network-clock-participate wic 0
no network-clock-participate wic 1
Also, with the set-up of the card can we run voice and data on the same card through the 2 interfaces or do we need separate cards?
what is this for?
Rick
Re: First time with E-1 - need some help
You can use the same card, it just needs to be all E1 or all T1 if its a 2MFT-T1E1.
the voice I believe he was trying to tell you its an E1 R2. There is 3 versions. compelled, semi-compelled and non-compelled. I myself have never worked with on in the wild so this is far as I can get you. I think its like
ds0-group 0 timeslots 1-10 ... semi-compelled
Paolo or someone could answer this better ;)
HTH,
Chad
Silver
Thanks Chad...
I was able to find this link:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800ad389.shtml
I just wanted to make sure that the data and the voice could be on the same card and that there are no issues. There should not be a problem since it is two different controllers and interfaces but never done this so I wanted to make sure.
It is slowly making sense, but I am not quite there completely yet.
199
