fixed IP phone config
Can I have DHCP enabled on Cisco IP phone and hardcode CM IP address at the same time ?
Thank you
HH
2 ACCEPTED SOLUTIONS
Hi Aaron
If your problem is the name resolution, you can modify Call manager server name with its IP address and phone will no longer asked to resolve the name of CUCM.
In this case you need to modify enterprise parameters for URLs for Corporate Directory and IP Phone services.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Super Bronze
Where did you change the server name? You should change the server reference in the System/Server page of CCMAdmin, not the actual server hostname on the OS Admin or CLI.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi.
With IP Phone using SIP you can modify the XML configuration files fixing the CUCM IP Address and upload these files to the phone with an alternate tftp server.
Carlo
Carlo
It is SCCP phone , I want to do that because I have centraized TFTP server which provide .cnf.xml files to the phones , and I dont have DNS and no plan to have it , so when the phone receive to .cnf file , it tries to register with the CM and "Registraion rejected , security error " message shown on the phone , when I check status messages it shows DNS lookup time out , so I configure DNS on my machine just to test and it works fine .
Now I am looking for solution to avoide use DNS and able to register with CM with it's IP .
Thanks Carlo
Super Bronze
You can set DHCP, the disable it - and the phone 'remembers' the assigned address. Once disabled you can edit the TFTP setting.
Alternatively any decent DHCP server will allow you to set a reservation for the MAC address in question, and specify different options for it (e.g. a different Option 150 setting).
Aaron
Please rate helpful posts..
MY TFTP server is CUCM server , and there is no way to edit the tftp setting inside it , it is just enable or diable the serivce , more over if I disable the tftp on the phone still I can't edit the CM address .
Thanks Aaron
Hi Aaron
Carlo
Hi Carlo ,
I have tried this , and then I had a cluster DBreplication problem , Even after change the server name to It's IP , from the TFTP  was still pointing to Publisher by it name not IP address .
Super Bronze
Aaron
Hi.
I would also add to what Aaron suggested, to change the name to IP address even in Cisco Unified CM in System Menu.
Carlo
I have changed it and reset the cluster ,and it work fine , thank you guys
394
