Community Member
Fixed Number Display
Hi All,
I am using CCM version 5.x . We have got PSTN gateway 2851 router on which PRI is terminated for making outgoing & receiving incoming calls from PSTN world.
The problem which I am facing is that number being displayed at receiver end is 460XXXX.
What we want is that no. to be displayed should be 460YYYY for all outgoing calls which are made from IP phones to PSTN world.
Is that possible? Pls. guide.
regds,
aman
1 REPLY
Re: Fixed Number Display
yes, you need to configure that mask as the calling party transformation under the route pattern
if you set it to 460XXXX the number will be 460 + 4 digit extension
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
109
