02-07-2014 05:29 AM - edited 03-16-2019 09:38 PM
In Cisco ccw after selecting C3925-CME-SRST/K9 it automatically include 25 srst license.
Then is possible to choose fl-cme or fl-srst.
What is the difference considering that in both cases 25 srst license are included?
Solved! Go to Solution.
02-09-2014 09:03 AM
If the client would like to add same cucme in different locations in srst is it enough to by the required srst licenses in each location based on the number of phones in each location?
Correct, you buy it per site
Are there any licensing differences if the cucme are configured in srst or each cucme work as "standalone"?
No, as I stated these are interchangable.
HTH, please rate all useful posts!
Chris
02-07-2014 05:35 AM
They are interchangeable, so it does not matter.
Chris
02-07-2014 07:54 AM
02-09-2014 09:03 AM
Chris
