03-28-2014 12:05 AM - edited 03-16-2019 10:17 PM
Hi, everyone!
I am little bit confused with FL-CUBE license on ISR G2.
I cant understand, when exactly i need to purchase them.
In which case i need them?
- to connect CME with any analog gataway, for example VG224
- to connect CME with any other gateway, ISDN or E1, for example.
- to connect CME with CUCM/CME
- to connect CUCM with any other IP telephony systems, Avaya for example.
- to connect CME with UNITY
- to connect CME with ISP PSTN via SIP/H.323.
- to connect CME with H.323 phones.
Solved! Go to Solution.
03-28-2014 03:12 AM
The reason for running cube is to move calls between protocols
Like:
SIP to SIP
SIP to H323
or the other way around.
You CAN run cube on a CME, it´s just a matter of configuration (and licensing) but it is not required. If you are not using sip for trunks to cucm or sip to a provider you don´t need it.
03-28-2014 01:26 AM
From all the above only this one:
- to connect CME with ISP PSTN via SIP...
And maybe
- - to connect CUCM with any other IP telephony systems, Avaya for example if it's going to utilize SIP perhaps...
HTH,
Dragan
03-28-2014 03:12 AM
Like:
SIP to SIP
SIP to H323
03-28-2014 03:56 AM
So, if a need to make trunk between CUCM in central office and CME in branch, i need FL-CUBE license?
Trunk type beetween them must be SIP? Or via any other protocol?
03-28-2014 05:02 AM
ahh, licensing, it´s a beauty isn´t it :-)
Do you have terminating isdn on the cme that needs to route to cucm?
If so, yes. If no - not sure :-) - probably not but I would doublecheck with a cisco sales rep just to be sure.
Yes you run sip to cucm. You can do H323 on the trunk as well but if you do not have any h323 devices on the branch, sip is the way to go.
