Community Member
Flow Control
Hi there,
I'm having some voice quality problems... and looking the gateway interface I notice that the flow-control is XON ... but in the 6500 side flow-control is off
Could this be a problem ?
Gateway Interface
GigabitEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0019.2f8e.2761 (bia 0019.2f8e.2761)
Internet address is 10.1.9.33/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000000 bits/sec, 681 packets/sec
5 minute output rate 928000 bits/sec, 639 packets/sec
163683848 packets input, 3762139914 bytes, 0 no buffer
Received 48968 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
0 watchdog, 0 multicast, 0 pause input
150513153 packets output, 1792803827 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier, 1 pause output
Switch Interface
GigabitEthernet11/33 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0018.b9d1.1ab8 (bia 0018.b9d1.1ab8)
Description: Connected to the Gateway
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:45, output 00:00:30, output hang never
Last clearing of "show interface" counters 1w0d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 1459000 bits/sec, 989 packets/sec
5 minute output rate 1585000 bits/sec, 1087 packets/sec
163640409 packets input, 30646597890 bytes, 0 no buffer
Received 12370 broadcasts (12332 multicasts)
183757176 packets output, 33210162692 bytes, 0 underruns
Thanks.
Andrei.
162
