FoIP - SIP trunk & T.38
We created a SIP trunk from our CUCM to a FAX server.
The FAX server requires T.38 and we created T.38 on a MGCP gateway.
The traffic arrives at the FAX server from the CUCM SIP trunk but nothing is received on the FAX server from the MGCP gateway.
How do we bind the SIP trunk to the MGCP gateway to initiate T.38 for the FAX server?
Can the CUCM convert a G711 fax to T.38 without a gateway, if so how?
Attach a .PNG file with the diagram
Hi Henry,
     So if I understand correctly; incoming faxes over the MGCP gateway do not reach the fax server on the other end of the SIP Trunk from the CUCM?
Which makes your call flow: PRI >> MGCP Gateway >> CUCM >> SIP >> Fax server.
Also, to answer the last part of your query:
> All fax cals start as Audio calls and then get stepped up to a Fax call.
> The recieving fax machine escalates the call to a fax call; mostly using a method called the Protocol Switchover.
> In our case, for an incoming fax the fax server will send the CUCM a SIP Re-INVITE and will negotiate T.38 with the CUCM.
> The CUCM will negotiate the same using a MGCP MDCX ( Modify Connection ) and if everything works out, the voice call will escalate to a fax call.
> If we had two fax servers on both the ends of the CUCM, it would still be able to escalate the call to a fax call, regardless if agteway is involved.
Please confirm the call flow and I shall then let you know if I need more information on this. Please also include the "show run" from the gateway.
Thank you.
Jagpreet
Jagpreet
Thank you. I will send the "show run" as soon as possible.
Henry
Jagpreet
The fax flow is as follows.
Incomming FAX:
FAX Machine - PRI - Voice Gateway - MGCP - CUCM - SIP Trunk - FAX Server (T.38)
Outgoing FAX:
FAX server (T.38) - SIP Trunk - CUCM - MGCP - Voice Gateway - PRI - FAX Machine
"SH RUN"
isdn switch-type primary-ntt
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
fax interface-type fax-mail
controller E1 0/0/1
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
description Telkom FAX PRI Cct number: 0126822000
interface GigabitEthernet0/0
ip address 172.18.2.7 255.255.255.0
ip flow ingress
duplex full
speed 1000
h323-gateway voip bind srcaddr 172.18.2.7
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/1:15
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.18.10.23
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.18.10.21 172.18.10.23
ccm-manager config
mgcp
mgcp call-agent 172.18.10.21 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 14400
mgcp fax t38 nsf 000000
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.18.10.21 identifier 1 version 6.0
sccp ccm 172.18.10.23 identifier 2 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register CENT-VGW1-XCOD
sccp ccm group 2
associate profile 2 register CENT-VGW1-CFB
dspfarm profile 1 transcode
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
maximum sessions 30
associate application SCCP
dspfarm profile 2 conference
codec g729ar8
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
maximum sessions 8
dial-peer voice 100 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:172.18.22.9
dtmf-relay rtp-nte
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
gateway
timer receive-rtp 1200 isdn switch-type primary-ntt
voice service voip
sip
voice-card 0
dspfarm
voice-card 1
dspfarm
controller E1 0/0/1
framing NO-CRC4
ip flow ingress
duplex full
speed 1000
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/1:15
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
mgcp fax rate 14400
sccp
sccp ccm group 1
sccp ccm group 2
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
maximum sessions 30
codec g729ar8
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
maximum sessions 8
dtmf-relay rtp-nte
gateway
Henry
Jagpreet
Thank you. I will try it tomorrow and let you know.
Thank you for the assistance so far.
Henry
Hello Henry,
     Any luck with the fax calls after the changes?
Jagpreet
Hello Jagpreet
No luck yet. Busy collecting the CUCM traces. Will attach them tomorrow morning.
Thank you
Henry
Hello Jagpreet
How do we tell the SIP Trunk on the CUCM 9 to use the MGCP gateway?
We do not see any traffic from the gateway to the FAX server.
The CUCM traces.
INVITE sip:1680@172.18.22.9:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b1126934f7a4
From: <0827870874>;tag=555019~32cbe58c-b967-436d-b4b4-945270831153-36792489
To: <1680>
Date: Wed, 06 Nov 2013 11:12:00 GMT
Call-ID: 40734580-27a12400-127fc-150a12ac@172.18.10.21
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <172.18.10.21:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1081296256-0000065536-0000000424-0352981676
Session-Expires:  1800
P-Asserted-Identity: <0827870874>
Remote-Party-ID: <0827870874>;party=calling;screen=yes;privacy=off
Contact: <0827870874>
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 101 INVITE
To: <1680>
Via: SIP/2.0/UDP 172.18.10.21:5060;received=172.18.10.21;branch=z9hG4bK1b1126934f7a4
Content-Length: 0
SIP/2.0 180 Ringing
Allow: INVITE,BYE,ACK,OPTIONS,CANCEL
Contact: <1680>
CSeq: 101 INVITE
Server: Netbricks-Sip-T.38IAF/v2.8.0 (Fenestrae, (14 Dec 2010))
To: <1680>;tag=7E3-F9
Content-Length: 0
SIP/2.0 200 OK
Contact: <1680>
Content-Type: application/sdp
CSeq: 101 INVITE
Content-Length: 209
v=0
o=Ampath 2890844526 890844526 IN IP4 netbricks.com
s=-
c=IN IP4 172.18.22.9
t=0 0
m=audio 10012 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
m=audio 10012 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
ACK sip:1680@172.18.22.9:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b11383ec72d
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
BYE sip:1680@172.18.22.9:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b11415b89dd
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=47
Content-Length: 0
SIP/2.0 200 OK
Contact: <1680>
CSeq: 102 BYE
Via: SIP/2.0/UDP 172.18.10.21:5060;received=172.18.10.21;branch=z9hG4bK1b11415b89dd
Content-Length: 0
Another trace
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b11d2f5e47b7
From: "Manie Beneke" <0126781605>;tag=555034~32cbe58c-b967-436d-b4b4-945270831153-36792534
To: <1680>
Date: Wed, 06 Nov 2013 11:12:15 GMT
Call-ID: 49641700-27a1240f-12804-150a12ac@172.18.10.21
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 1231296256-0000065536-0000000425-0352981676
P-Asserted-Identity: "Manie Beneke" <0126781605>
Remote-Party-ID: "Manie Beneke" <0126781605>;party=calling;screen=yes;privacy=off
Contact: <0126781605>;video;audio
Max-Forwards: 70
Content-Length: 433
v=0
o=CiscoSystemsCCM-SIP 555034 1 IN IP4 172.18.10.21
s=SIP Call
c=IN IP4 172.18.143.167
b=TIAS:768000
b=AS:768
t=0 0
m=audio 25280 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
m=video 25320 RTP/AVP 97
b=TIAS:760000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=420014;packetization-mode=0;max-mbps=36000;max-fs=1280;level-asymmetry-allowed=1
a=content:main
SIP/2.0 100 Trying
CSeq: 101 INVITE
To: <1680>
Via: SIP/2.0/UDP 172.18.10.21:5060;received=172.18.10.21;branch=z9hG4bK1b11d2f5e47b7
Content-Length: 0
SIP/2.0 180 Ringing
Contact: <1680>
CSeq: 101 INVITE
To: <1680>;tag=7E3-E224
Content-Length: 0
SIP/2.0 200 OK
Contact: <1680>
CSeq: 101 INVITE
Content-Length: 244
v=0
o=Ampath 2890844526 890844527 IN IP4 netbricks.com
s=-
t=0 0
m=audio 0 RTP/AVP 18 101
a=fmtp:101 0-15
a=ptime:20
m=video 10012 RTP/AVP 97
b=TIAS:39104
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b11e4e8c898d
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
BYE sip:0126781605@172.18.10.21:5060 SIP/2.0
CSeq: 2 BYE
Max-Forwards: 70
To: "Manie Beneke" <0126781605>;tag=555034~32cbe58c-b967-436d-b4b4-945270831153-36792534
User-Agent: Netbricks-Sip-T.38IAF/v2.8.0 (Fenestrae, (14 Dec 2010))
Via: SIP/2.0/UDP 172.18.22.9:5060;branch=z9hG4bK51A5F06
Content-Length: 0
SIP/2.0 200 OK
Date: Wed, 06 Nov 2013 11:12:16 GMT
CSeq: 2 BYE
Content-Length: 0
Henry
Do you have the possibility to run Wireshark on your fax server ? If yes look at the SIP SDP message sent from CUCM. You normally should see the IP address of your MGCP gateway as the originating point for the media transfer.
If really you do not see any traffic and it's not a negociation issue then it could be a IP routing issue between your gw and the fax server (no route to destination).
JC
Hello JC
Thank you for your reply.
Please see my reply to Jagpreet
Henry
Reason: Q.850;cause=47  means codec issue.
Do you have transcoding ressources configured ?
It is unclear what you are getting at here. First, you need to be clear if the provider supports t.38 or not. If they don't support T.38, your best bet is to nail up a g.711 call to the provider, and you'll get best-effort faxing which should be fine at low speeds. High speed fax and modems would be sketchy at best across a g.711 call in voice mode. You can use specific device pools/regions/dial-peers to acheive this such that calls from/to the fax numbers always are g711 from the start of the call.
Keep in mind that if you are doing any switchovers via NSE (gw-controlled MGCP, SCCP, or nse-forced) then make sure you aren't invoking the MTP, as MTPs don't pass NSEs properly out the other side. Modem passthrough is Cisco proprietary, so you'll never get that to work with a non-Cisco equipped SP. Furthermore, modem passthrough requires an NSE based switchover, which isn't going to work with the MTP as noted above.
You can invoke an MTP for a T.38 call, as long as 'codec pass-thru' is specified. Obviously, your provider needs to support T.38, though. You need to ensure that you use protocol-based switchovers for this (CA-controlled with MGCP, or via H.323 RM/SIP Re-INVITE messaging.)
Fax pass-through switchover is essentially just an upspeed to g711ulaw once the call is established via the call-control protocol messaging, so you can do this with an MTP.
Whether you are doing SIP or H.323, capabilities are the same on the MTP from a functional perspective, since the MTP is really only speaking SCCP anyway.
As far as DTMF-relay goes, the only thing relevant to talk about is RTP-NTE and in-band audio. All other types of DTMF-relay follow the signaling path, and are irrelevant from the perspective of an MTP (which terminates media). If you need to convert DTMF to-from in-band audio, you need a transcoder. Converting RTP-NTE to another type of DTMF-relay (H245-alpha/signal, SIP notify, etc.) can be done with a software or hardware MTP, as well as a transcoder.
Your CUCM says BYE to your fax server. You haven't even reached the first step negociation with G711 A-law or mu-law
The other trace involving Manie Beneke shows you use G729
You need to allow G711 codec with your fax server.
You've put your SIP Trunk into a Device Pool. According to this Device pool - specific if well done to your Fax Server - check the associated Region Settings. The "Max Audio Bit Rate" of this region must be set to G.711.
JC
Thank you JC. Will check and let you know.
Henry
JC
We made the changes as you mentioned, but still no luck. Below the new trace.
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b94748acfd76
From: <0827870874>;tag=563017~32cbe58c-b967-436d-b4b4-945270831153-36920033
To: <1680>
Date: Thu, 07 Nov 2013 10:25:08 GMT
Call-ID: dec7df80-27b16a84-12dee-150a12ac@172.18.10.21
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 3737640832-0000065536-0000000437-0352981676
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 101 INVITE
To: <1680>
Via: SIP/2.0/UDP 172.18.10.21:5060;received=172.18.10.21;branch=z9hG4bK1b94748acfd76
Content-Length: 0
SIP/2.0 180 Ringing
Contact: <1680>
CSeq: 101 INVITE
To: <1680>;tag=7E3-82D6
Content-Length: 0
SIP/2.0 200 OK
Contact: <1680>
CSeq: 101 INVITE
Content-Length: 209
v=0
s=-
t=0 0
a=ptime:20
a=ptime:20
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b9487405e87c
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Via: SIP/2.0/UDP 172.18.10.21:5060;branch=z9hG4bK1b94937a13016
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
SIP/2.0 200 OK
Contact: <1680>
CSeq: 102 BYE
Via: SIP/2.0/UDP 172.18.10.21:5060;received=172.18.10.21;branch=z9hG4bK1b94937a13016
Content-Length: 0
Henry
VIP Super Bronze
Henry,
What is the region setting between the gateway and the sip trunk set to? From the trace it looks like it is set to G729. Your fax server wants to do either G711u or G711alaw..But CUCM cant do any of that codec, this is most likely due to region settings..Please check this and ensure that it is set to G711
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
The region is set to G711. If you look at the latest attach trace "0 PCMU/8000 a 0 PCMU/8000 a" means that we use G711. Where in the trace do you still see G729.
Thank you
Henry
VIP Super Bronze
That is what your fax server is advertising. That is the 200 OK from your fax server. CUCM needs to send an ACK to that 200 ok and the codec used will depend on the region between the gateway and the sip trunk to the fax server. Can you send the full cucm traces?
I will ask the customer for the traces and will forward them to you ASAP. That will most likely be later tonight or tomorrow.
Thank you
Henry
"0 PCMU/8000 a 0 PCMU/8000 a" is what your fax server asks to CUCM, which is unable to do so because the Region is not allowed to use G711.
If you have configured this setting into the Region have you reset the SIP Trunk to apply changes ?
We will setup a test environment tomorrow. We will configure it separately from the life environment and then run the test. Will update as soon as the tests are finish.
Thank you all for the assistance so far.
Henry
Re:FoIP - SIP trunk & T.38
Henry,
As Aok said, we need the complete CCM traces to move forward on this.
Jagpreet
Sent from Cisco Technical Support Android App
2186
