Community Member
Force Authentication Code(FAC) on one phone
Is there any way to configure FAC to be used only on one phone?
In other wards,
If I have 100 users and each user has his own FAC, if this user try to use his code on other phone he will not be able to place call. He can just place calls from his phone set.
Is it possible????
Bronze
Re: Force Authentication Code(FAC) on one phone
Hi, I think that is not possible because FAC is associated with Route Patterns and not with IP Phones.
All the best.
David.
Community Member
well the only way I can see you doing this is assigning unique Partitions and CSS for each user and use FAC level for each user as well as Route Patterns.
It's a lot I know but the only limitation is the Hardware specs of your CallManager Server
476
