Community Member
Force Authorization code in CME
Dear all,
i need help is there any way to configure FAC in CME 7.0.as i need to block international access on pots & voip dail peers  using FAC code  all the time not only after office hrs.
i have gone through all the doc related to call blocking but while configuring the same. i face below mentioned issue
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html
1)  how can I block the dial peer for all times. The option I have is to restrict only during specified timings.
2) According to the document I configured "login" in the template, and the login does work, but it does not matter whether I am logged in or not, the calls are still going through.
I would appreciate if some one has alreday done this & help me out ..
Hi there,
Forced Authorization Codes were introduced in CME 8.5 and later:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html#wp1011721
Feature Name
Cisco Unified CME Version
Modification
8.5
Introduced the FAC feature.
HTH,
Chris
Community Member
I know this feature is avialable in 8.5 version , but is there any workaround for this in 7.0 version.
Blue
As a workaround, You can use script mentioned in below link. Name of script is " Clid_authen_collect.tcl "
http://www.cisco.com/en/US/docs/routers/access/as5350/software/feature/guide/pull_ivr.html#wp1021162
Please note :- The scripts are not supported by TAC.
regards
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Thanks Ronak for your valuable inputs..
but when i try to put below mentioned cmmd in my cme  router there is no such cmmd available my CME IOS verison is 15.0 M7
call application voice
Blue
hi
Command is changed use following command.
Router(config)#application
Router(config-app)# service ?
Ronak Patel
720
